Transfer case or differential
Old May 21, 2020 | 10:59 PM
Wd1793's Avatar
Default Transfer case or differential
I’m hoping someone can point me in the right direction. I have a 2008 H3 and I lost front wheel drive in all three settings. However I was able to get the rear wheels to move in 4Low for a short distance until I lost that too. Now when I place the vehicle in park it rolls. I have no forward, reverse or ability to place the car in park. Would that be the front differential and transfer case.
when the gas is pushed the front drive shaft does rotate but will not go forward. When placing the car in park I hear a loud clicking noise coming from the transfer case.
Old May 22, 2020 | 01:15 AM
Happy Hummer's Avatar
So, if I understood your post???
Lol.
The front ds turns when placed in drive?
Is there pop'n or chattering while pushing accelerator ? Meaning in drive and 4L engaged...
Does the front differential attempt to rotate the tires?
Have you drained the front differential and removed the cover to inspect it?
You could have a damaged shift fork. A damaged transmission. A damaged front differential.
Time to test the vehicle with all four wheels off the ground.
Old May 22, 2020 | 08:59 AM
POPCORN
Old May 23, 2020 | 08:21 AM
Miles on the H3. Recent work done?
When was the last time you changed the Trans Fluid and filter?
Old May 25, 2020 | 04:09 PM
H3Luxembourg's Avatar
Looks like a bad T case , drain oil and watch the color of it. Maybe the fork of the T case shift is out
Wd1793
May 23, 2020 11:40 AM
charlie6017
Jun 11, 2019 12:22 PM
Donnie6983
Nov 19, 2017 12:11 AM
Tim Moore
Sep 20, 2017 09:42 AM
FatJay
Apr 20, 2017 06:36 AM
