traction failed, service stab, reduced power back on
Old Jun 20, 2019 | 10:34 AM
Ferne Singer's Avatar
Default traction failed, service stab, reduced power back on
replaced the Pedal assembly sensor (which the code called for when this previosally happen 3 days ago) and now its back, new throttle body or would a good throttle body cleaning do the trick? is their a chance the 2 are not talking/linking up?
Old Jun 20, 2019 | 10:38 AM
at the level of diagnostics that you are at right now you really need a scan tool that can help you determine those questions. something like a tech2 programmer or one with bi directional controls where you can read sensor / feedback info and allow independent activation tests.
with some of the info i have seen you inquire about i am sure you are more then capable of sorting this out.
Old Jun 20, 2019 | 11:28 AM
Broken Halo's Avatar
Start with the easy/cheap stuff. Pick up some MAF cleaner and Throttle Body cleaner for about $8. See if you still get the code after cleaning.
Old Jun 20, 2019 | 02:39 PM
If you have not cleaned the Throttle Body recently (or within the last 10K miles), I would do that first before throwing parts at the problem. Easy stuff first.
The messages you are describing can be caused by many different issues so we would need more info to help.
Old Aug 5, 2019 | 09:06 AM
Jennitran's Avatar
Visit Autoguysland to review more OBD2 scanner that you may concern.
There is one post related to your issue. You can refer it if it can help you or not.
https://www.hummerforums.com/forum/h...d-power-24202/
Jbrashers
Nov 21, 2019 09:32 AM
Terrielle
Aug 12, 2018 03:13 PM
DesertDog
56
May 5, 2018 05:57 AM
Alex Polazzo
Jul 3, 2017 12:42 PM
Conway 501
Mar 22, 2017 09:31 AM
