Taillight when signalling
Old Mar 26, 2026 | 08:17 PM
Me 2's Avatar
Default Taillight when signalling
Anyone ever see this before? Wasn?t happening a couple weeks ago. When using the signal to the left the left taillight bulbs all signal. Checked fuses, switched the bulb harness to the right and works fine. All front lights and right rear work normally. No fast blinking.
File Type: mov
Old Mar 27, 2026 | 02:59 PM
NMH3's Avatar
Looks like yours has been modified from stock, including an extra bulb? Maybe start with that?
Old Mar 27, 2026 | 03:03 PM
Me 2's Avatar
Sorry, should have mentioned it?s a H3t.
Old Apr 14, 2026 | 07:39 PM
Me 2's Avatar
Update: found that if I switch the 2 taillight harnesses with the same bulbs the blinking issue remains on the left side. So not the bulbs or harnesses. I replaced the clock spring on the steering wheel because it looked rough and I have a seatbelt light on also. Checked the condition of the BMU and looks fine. Checked trailer and taillight fuses. Remounted the ground in the rear for the wiring harness. Still no changes.
Old Apr 15, 2026 | 09:26 AM
Do you have a scanner capable of reading the ABS module and system? If not, get one or have a scan done and post the code(s) if any.
Where you said BMU, did you mean Body Control Module????
Old Apr 15, 2026 | 09:33 AM
Me 2's Avatar
Sorry, yes its the BMC I was referring to. I will see if i can find any codes tonight, ty
mrmseto
Dec 16, 2024 02:31 PM
Stace723
Hummer H2 SUT
Mar 20, 2022 09:54 AM
jman1335
Oct 9, 2019 10:10 AM
nijoma
Dec 17, 2013 07:54 PM
charks1
Apr 22, 2010 06:29 AM
