Stiff Gear Shifter
Old Oct 1, 2019 | 09:17 AM
jman1335's Avatar
Default Stiff Gear Shifter
I've noticed in the last few days when I shift my gear shifter from park to drive, when it gets down to drive it feels a little "stiff." Going from Drive to D3 (which I have never, ever used) is very stiff. But then going back to parking is for the most part fine. All driveability (and transmission shifting while driving) seems fine and as per usual.
Just noticed it more stiff in and around D and the back of D/ closer to D3.
Is something gummed up? Should I take apart and lube something? Looking for any advice from anyone whose had similar issues
Old Oct 1, 2019 | 09:43 AM
you can inspect your shift cable at the transmission to see if it is rusted or binding. while your there check the state of the bushing that holds it onto the transmission range selector.
Old Oct 1, 2019 | 10:00 AM
jman1335's Avatar
Where is that located? Fairly easy to get to with a creeper/ light?
Old Oct 1, 2019 | 10:07 AM
literally right on the side of the transmission. https://www.gmpartsgiant.com/parts/g...-25800702.html
Old Oct 1, 2019 | 10:08 AM
jman1335's Avatar
Great, thanks for the heads up! Will do and will get back to you. Maybe its gummed/ gunked up, will clean and lube.
Old May 3, 2020 | 09:22 PM
Joegrillo's Avatar
Default Bronx tech
All the other ranges lite up P D 321 JUST NOT THE N but it is in NEUTRAL ON THE SHIFTER no problem just the lite not lighting should I deal with it or just forget about it
.How much is the part I cant find it
Hats2theback
Sep 21, 2021 11:29 AM
Jeff Wagner
Aug 23, 2019 01:57 PM
hummer_on_fumes
Jan 27, 2018 11:01 AM
BoltsFan87
Dec 3, 2013 10:05 AM
v0521
Mar 26, 2008 08:30 AM
