steering rack bushinhgs
Old Oct 30, 2019 | 01:05 PM
H3Luxembourg's Avatar
Default steering rack bushinhgs
It's time to change them, they do have too much movement. Waiting for the new ones kit: Ultimate power steering bushings
Old Oct 31, 2019 | 06:05 PM
wpage's Avatar
Did you try lubrication first?
Old Nov 1, 2019 | 02:21 PM
No that's not the problem, few days ago at our yearly technical inspection, they showed me the play that they have, so i will change them before i fail at the next inspection ( they are like TüV in Germany, very strict inspections)
Old Nov 1, 2019 | 03:18 PM
Lubrication will NOT correct this:
Old Nov 2, 2019 | 04:20 PM
Exactly the reason why it needs to be changed, and the ULTIMATE kit will do the job.
Old Nov 3, 2019 | 06:57 PM
wpage's Avatar
Exposing my steering joint when pulling the driver side wheel and wheel well. showed a extreme need for lubrication.
Lack of lube would over time cause a fail to this joint.
Old Nov 3, 2019 | 07:13 PM
Old Nov 4, 2019 | 02:59 PM
he just bought the wrong kit
Old Feb 9, 2024 | 12:54 PM
Tony-Nav's Avatar
follow-up, @teahead @hummerz @Doc Olds Tbanks for all the advise. Steering columb and Od bracket hung and issue fixed. Tread depth is good, recal of steering sensor and alignment and tires rotated. So far A1. Thanks for this forum and your expertise. Really appreciated!!!
Cohiba54
Mar 16, 2017 04:49 PM
lepack
May 25, 2014 07:46 PM
jamiw
Jul 10, 2013 10:15 AM
ava327
Aug 10, 2011 02:48 PM
jmamadog
Apr 5, 2011 05:27 PM
