Steering fluid correct level
Old Dec 27, 2019 | 04:43 AM
Cymru's Avatar
Default Steering fluid correct level
Can anyone help with determining the correct level for the power assist fluid? The dipstick goes into a slot below the cap and seems to me that the cross hatched area on the dipstick is much lower than that.
Old Dec 27, 2019 | 10:29 AM
From the owner's manual:
"How to Check Power Steering Fluid
1. Turn the key off and let the engine compartment cool down.
2. Wipe the cap and the top of the reservoir clean.
3. Unscrew the cap and wipe the dipstick with a clean rag.
4. Replace the cap and completely tighten it.
5. Then remove the cap again and look at the fluid level on the dipstick.
The level should be between the ADD and FULL marks. If necessary, add only enough fluid to bring the level up to the proper range."
The range between add and full is the cross hatched area.
Old Jan 2, 2020 | 09:26 AM
Cymru's Avatar
Sorry not getting back. Been away.
Anyhoo, checked the steering fluid this morning after the H3 has been standing for a week and it was a little over maximum on the dipstick. Went for a short ride and noted a grumbling from the steering. Opened the cap (after stopping the engine) and the liquid was right up to the top and full of bubbles.
Any thoughts?
finall
Apr 24, 2024 12:52 PM
oceanbrave
Jul 18, 2017 07:03 AM
BlueH3
May 16, 2015 08:05 PM
tx_pilot
Nov 29, 2010 12:17 AM
uzz32soarer
Oct 30, 2009 08:15 AM
