smoke coming from oil dipstick and filler hole
Old Mar 18, 2023 | 07:20 PM
Eurynomestolas's Avatar
Default smoke coming from oil dipstick and filler hole
I5 07
for some reason i noticed this. Then started looking into. i read that its something to do with the pvc. which h3 is on the valve cover. so i took a air hose and blew air down the driver side because i read that is what gets clogged and it was really bad. I notice the smoke is still coming even after trying to fix. any idea what else it could be? could it have gotten clogged again?
Old Mar 19, 2023 | 06:53 PM
The positive crankcase ventilation (PCV) is a simple system that introduces filtered fresh air into the crankcase. The PCV uses the engine's vacuum to pull air through the crankcase and reintroduce it back into the intake manifold.
Old Mar 19, 2023 | 07:26 PM
do you know why i would still be getting smoke
Old Mar 20, 2023 | 05:01 PM
Justinh's Avatar
How does fresh air get into the crankcase? When you turn off the engine?
Old Mar 20, 2023 | 05:25 PM
Old Mar 20, 2023 | 05:33 PM
Valve cover inlet/outlet/intake ports needs to be cleared for the engine to breathe properly.
Old Mar 20, 2023 | 11:40 PM
Disel's Avatar
I5 07
dead engine. Lots of burnt gases. Look at the exhaust pipe, there will be a lot of soot.
Old Mar 21, 2023 | 04:52 PM
Justinh's Avatar
Oh, I've read here on the forums that the pass side port is like a backup to the driver side port. Maybe the pass side acts as a backup only when the driver side is not functioning. Thanks.
Old Mar 21, 2023 | 05:35 PM
You need both, pass side=fresh air intake & drivers side=intake manifold vacuum.
Watch this:
Old Mar 31, 2023 | 12:43 PM
Watch this:
https://youtu.be/EPIfI9aZHt4
installed new valve cover. Still having the issue…. any ideas?
