Smittybuilt OverlanderXL ok to use on H3?
Old Jan 3, 2021 | 07:18 AM
Eric Jolly's Avatar
Default Smittybuilt OverlanderXL ok to use on H3?
I have a 2008 H3. I'm looking at rooftop tents.
Is anyone using the Smittybuilt Overlander XL?
If so, does it fit well? Did it require any adaptations?
Do you endorse or oppose using said tent?
I'm a worry wart and would like to hear from some people about both form and function on these tents before I drop the money for one.
Old Jan 4, 2021 | 07:47 AM
Welcome to HF
Old Jan 4, 2021 | 11:15 AM
Welcome EJ. Next time, before posting anything anywhere, please read. The HF Help & Suggestion Center is NOT for any vehicle questions and states in the top sticky thread: Do NOT post vehicle questions in this section
All H3 questions go in the H3 section.
Good luck.
Old Jan 4, 2021 | 01:43 PM
Why would anyone spend $1k+ to sleep on the roof? You don't need a ladder if you pitch a tent on the ground. Check out SUV tents and stay off the roof, before you break something.
Old Jan 4, 2021 | 05:09 PM
Eric Jolly's Avatar
I apologize. never done the blog thing before and struggling to figure out what I'm doing.
I'll try to find the H3 section.
Old Jan 4, 2021 | 05:16 PM
Eric Jolly's Avatar
hummerz,
I respect your opinion and defend your right to have a differing opinion.
I do, however, have my reasons and, as a rock climber, if I can't handle a ladder then maybe I should find a new hobby.
I find myself wanting to camp in locations that are not conducive to sleeping on the ground.
Thank you, kindly, for your concern.
P.S. I'm a budget shopper and do not intend to spend $1k+ on the tent
Smittybuilt OverlanderXL ok to use on H3?I have a 2008 H3. I'm looking at rooftop tents.
Old Jan 4, 2021 | 06:17 PM
Originally Posted by Eric Jolly
hummerz,
6ft above ground is not a guaranteed safe place, pack more important things, like rambo.
Old Jan 5, 2021 | 06:29 AM
First, I will state I am NOT an over-lander so I know nothing about the actual RTT construction, style and/or quality.
Overlanding forums are going to be your best resource for that aspect.
Below is just some FYI stuff for ya.
*140lbs+ on the roof will definitely change the roll center of any H3 and not for the better.
*Might want to make sure the H3 roof rails can support the amount of weight you are planning on putting up there. Even a static load (open tent, you, supplies, etc.) can be a strain on the rivnuts holding the rails to the roof.
*Depending on the age of your H3 and condition I have seen the rivnuts holding the roof rail tracks rip right through the roof sheet metal. (Nugget in Australia had a catastrophic roof failure sue to a RTT).
Originally Posted by TAINTER
TRUE! the riv nut will pull right through, cracking the thin metal beneath it.
This is Nugget (long time H3 owner and avid over-lander from down under) who had 120KG (about 265lbs) on his roof every day.
He ripped the RivNuts through the metal.
Once he had sandwiched the thin roof metal with a plates above and below to distribute the load through out the entire roof rail per side he had no issues.
He also used multiple mounting points on the roof rail to distribute the weight. 2 Roof racks ain't gunna do it, OEM or not.
Old Jan 5, 2021 | 10:33 AM
How about we post one thread per topic? Please do NOT start another.
tomcormier
Oct 22, 2019 10:24 AM
joefromerie
Jan 28, 2011 12:41 AM
Davidh3
Jan 15, 2011 08:27 PM
summit
Oct 10, 2010 06:46 AM
HummerBlues
Sep 21, 2006 12:03 AM
