Shifting issues
Old Apr 3, 2023 | 12:20 PM
mountainriderjeff's Avatar
Default Shifting issues
When running between 45 and 65 my H3 shifts back and forth from OD. I’ve been told I need a new transmission. It doesn’t seem to be nearly as bad when the cruise control is on. Any ideas?
Old Apr 3, 2023 | 12:31 PM
Year, miles and model H3 would be helpful. Who be the people/person that told you a new transmission is needed?
If it is an I5, probably normal. The 4L60E is supposed to go into lockup at about 45 under low load. It will unlock when load or throttle demand is increased sufficiently that the PCM (2006 & 7s) or TCM (2008+) commands it.
Old Apr 8, 2023 | 11:06 PM
Disel's Avatar
[QUOTE=mountainriderjeff;399735]При беге между 45 и 65 мой H3 переключается туда-сюда от OD. Мне сказали, что мне нужна новая коробка передач. При включенном круиз-контроле все не так плохо. Есть идеи?[/QUOTE
How are engine RPM? Is the engine rpm stable?
Dtnations
Mar 19, 2024 01:11 PM
ggt667
May 19, 2022 05:37 PM
apollo18
Feb 13, 2020 04:10 PM
joenuzz
Dec 29, 2016 07:05 PM
daiglesbagels
Aug 31, 2014 08:57 AM
