Shadow Green Metallic H3 Build Thread
Old Dec 10, 2016 | 10:01 PM
Jayson DK's Avatar
Default Shadow Green Metallic H3 Build Thread
Hello All,
Proud to be a member of the forum here. I've always liked the look of an H3, and while I am in the middle of building a 2017 EcoRaptor, I decided this would make a great daily driver/winter vehicle until it's done.
I'm no newcomer to building modified vehicles. I think I can do something unique with this one, I love the Shadow Green Metallic & color matched interior. Here are some of my previous builds -
Lifted Avalanche LTZ:
625rwhp CTS-V Coupe:
A 573HP Supercharged STS-V:
A 584HP BMW M6:
My last salvage build was this custom turbo GT86 FR-S:
Just for ****s and giggles, my Sport Trac from way back in the day:
Old Dec 10, 2016 | 10:31 PM
Jayson DK's Avatar
So here is the H3:
First thing I did when I got it, was clean and replace the sunroof drains, then have a new body control module programmed, new keys, fobs, and replaced the ignition housing.
After that, came the fun stuff:
Complete amsoil flush of all fluids, using seafoam and amsoil flush products including:
New Oil & Filter
Full Transmission Flush w/ filter & Gasket
Coolant Flush
Front Diff Flush
Rear Diff Flush
Transfer Case Flush
Fuel System Clean/Flush
After that, it was on to the suspension. We replaced:
Both Wheel Bearings
Both Upper Control Arms
Both Lower Ball Joints
Front brake pads and rotors w/ new hardware & ceramic pads (boy were they whooped)
Front Stabilizer Links
Front inner & outer tie rods
After that, we noticed a leak in one of the trans lines, so we replaced both.
[URL=http://s782.photobucket.com/user/g1323/media/h3/20161208_195544.jpg.html]
Jayson DK's Avatar
[/URL]
Next comes the real fun stuff. Next updates will include:
Android 7" In Dash Quad Core Radio
Factory Speaker/Amp/Subwoofer Integration
Backup Camera
New Headlights w/ LED lighting
Custom Running Lights w/ LED Switch Back
New Fog Lights w/ LED Lighting
Custom Side Markers, smoked w/ LED lighting
Custom Fiber Optic Tail lights, tinted red
Tint windshield & front doors
After that, I will be:
Painting Grill Body Color
Front & Rear Bumpers Body Color
Accents in black
2 Way Remote Start
And after that:
3" leveling lift / shocks
1" Body Lift
35" Wheels / Tires
Mechanically, the truck is near perfect now. We have ran into one issue however. On the intake, there is a PCV dirty air hose that is not serviced separate from a new intake manifold. It is #2 in this picture:
The dealer is telling me it cannot be serviced without buying a new intake manifold assembly for around $300. Any suggestions? Is this true?
Old Dec 12, 2016 | 02:56 PM
H3s do NOT have a PCV valve, it is not a separate serviceable part. From the inside of the intake manifold it is just a baffle with some small holes in it and was designed to last the life of the truck.
Why do you think it needs to be replaced?
Old Dec 12, 2016 | 03:09 PM
Jayson DK's Avatar
Thanks for the reply. I can feel/hear air coming from down where #2 dirty air PCV tube is, and im positive thats where my stumble when I come to a stop or take off is coming from. If I plug it with my fingers, the RPMS dont drop.
Old Dec 13, 2016 | 09:10 AM
You may have a leak, just fix the leak with a small clamp or zip tie.
When you say you plug it with your finger and there is no stumble, I'm pretty sure you are not stopping or taking off while under the hood.
Stumbles with I5s usually come from a dirty TB and/or MAF.
Old Dec 13, 2016 | 06:40 PM
Check the intake manifold bolts. Some tend to come loose due to the I5s inherent vibrations.
Old Dec 29, 2016 | 11:28 PM
Charley12's Avatar
Any update on this build?
Old Jan 10, 2017 | 08:55 AM
Jayson DK's Avatar
Hi guys. Been quite busy. I ended up doing and replacing nearly everything on the H3 to make it like new. I'm happy to report it now feels like a new truck! I like my vehicles flawless or near flawless, so here are some pictures and details.
Installed new Double Din Android Nav radio & onstar/amp retain harness & install kit
Replaced new intake w/ gaskets
Replaced new exhaust manifold & catalytic converter w/ gaskets
Replaced all PCV hoses
Replaced all bolts / bushings on suspension
Replaced oxygen sensors
Replaced all interior/exterior bulbs with LED
Replaced both kick panels and door sills
Replaced radio bezel, 4x4 switch, heater a/c controller
2.5" tortion key front lift
2" rear lift shackes
4x Bilstein 5100 shocks installed
Replaced ball joints
Replaced all 4 OEM bump stops with factory
Replaced both power steering lines
Replaced air filter
Replaced rear brake rotors and pads w/ premium ceramic
Replaced TPMS sensros & program
Replaced belt tensioner
Replaced vent valve motor
Replaced encoder motor
Replaced upper and lower steering shafts
Jayson DK's Avatar
