Roof Leak????
Old Sep 23, 2013 | 10:45 AM
biglol's Avatar
open your sunroof and you will see a hole in each corner of the plastic moulding ... get your self an airline and blow down them ... you will here the pop from them as they unblock ..... the holes are there to take away the access rain water... hope this helps
Old Sep 23, 2013 | 10:48 AM
biglol's Avatar
Default weak central locking ??
does anyone have any ideas about central locking ... I've tried new battery's but still a weak signal ... I have to stand close to my hummer h3 ??
any clues would be helpful ... cheers Ian
Old Sep 23, 2013 | 07:14 PM
Ground Pounder's Avatar
Use K-Y Jelly instead of Vaseline on the rubber seals..
Old Sep 24, 2013 | 10:04 AM
supsam86's Avatar
Ground Pounder's got KY... hmm. (haha! Sorry man! I had to! )
Old Sep 24, 2013 | 10:34 AM
dan perez's Avatar
If you want to FIX the problem once and for all., follow the directions on this thread: https://www.hummerforums.com/forum/h...n-tubes-28548/ or go to page 5 for the posting titled "Finally, a fix for clogged sunroof drains". have fun !!
Old Mar 17, 2014 | 03:34 PM
Sushi Boy's Avatar
Ditto to what dan perez said, but I had to employ a combo of that thread and the weed trimmer line trick mentioned in post #10 of this thread.
It's nice not getting soaked after every rainstorm now.
Old Mar 19, 2014 | 11:56 AM
Mad rebel's Avatar
Default Roof leak
Uh, before I buy an H3 with a sun roof, is this a common problem?? 😳
Old Mar 19, 2014 | 12:10 PM
atari800's Avatar
this is probably a common problem for all moon/sun roofs
Click this to see all other car manufacturers with same issue
https://encrypted.google.com/search?...%20roof%20clog
Old Mar 19, 2014 | 02:47 PM
Bunger's Avatar
Yup, but once you do "the fix" linked above, it never leaks again.
PS, "the fix" is easy, don't let the instructions intimidate you.
Old Mar 19, 2014 | 03:13 PM
Mad rebel's Avatar
Gotcha!
