Ringing noise after throttle cleaning
Old Jul 9, 2013 | 08:01 PM
nelsonhood's Avatar
Default Ringing noise after throttle cleaning
I cleaned the throttle body today, together with changing the air filter (K&N) and spraying the MAF sensor with some MAF cleaner. After mount everything back (I took the throttle body out), I let the truck sit for about 2 hours. Then I took it for a test drive. No engine light, however, I noticed a ringing noise, like the ringing of a bell.
Maybe the noise was there before but I didn't pay attention to it. Does it sound familiar to anyone? What could cause the noise?
Old Jul 9, 2013 | 10:18 PM
jphh20's Avatar
I had a similar noise that had been coming from my a/c compressor clutch. As it turned out, the clutch and the compressor went bad. If you have a stethoscope, you can try to isolate where the noise might be coming from.
Old Jul 10, 2013 | 02:02 PM
nelsonhood's Avatar
It seems to be the AC compressor clutch.
With the AC off, the noise is not there (today there is some wind, so it's harder to listen). If you got a minute, please give it a listen and let me know it's my illusion or not. Thanks a lot!
Both fan and AC off:
Turn the fan on, AC still off:
Both fan and AC on:
Keep fan on, turn AC off:
H3-SC
Jul 15, 2019 06:54 AM
mt2ut1
Jan 1, 2017 10:07 PM
flex22
Dec 20, 2015 06:12 PM
David Stanley
Nov 5, 2014 03:12 AM
jvorpahl
29
Jan 13, 2014 03:31 PM
