Replacing u joint?
Old Aug 11, 2020 | 07:45 PM
bassackwards's Avatar
Default Replacing u joint?
While we are replacing the cv joint on the front driveshaft we decided to do the front u joint.
We removed the 2 C clips and put a large socket over one cap and a nut on the other and started tightening the vise. It was really tight so I used a cheater bar.
I think I stripped the guts out of that cheap chinese vise and the caps never moved. I am sure that I had sufficient clearance for the cap to push out but it did not budge. We are soaking it now but I'm wondering if heat is needed too?
Old Aug 11, 2020 | 08:31 PM
Got it with a hammer and a small socket on one side and the big one on the other. It took about 50 licks to get moving then it slipped right out
Old Aug 12, 2020 | 08:41 AM
You need a C Press, you can't pound them back in.... well I guess you could, but not on my trucks. Turns them in and out like butter.
OTC 7248 (just the press) does U Joints, Ball Joints, and Brake Anchor Pins. The OTC 7249 adds in cups for the Ball Joints, had mine for years.
crazyfool
Jun 8, 2020 08:28 PM
Mkawas
Oct 6, 2017 10:09 AM
CurtisP87
Mar 10, 2015 08:04 AM
smigelskijk
Sep 19, 2013 10:46 PM
Todd
Sep 18, 2008 03:54 PM
