Repeated U-Joint Failure
Old Nov 27, 2019 | 09:11 PM
jman1335's Avatar
Default Repeated U-Joint Failure
Replaced the original OEM Rear U-Joint at the Rear Diff in March, 2017 (classic U-Joint squeal noise) with a Moog greasable. It started to squeal and was seized in August of this summer (so, about 2 years), so it was replaced with a Napa greasable one. Now, this week, same squeal and mechanic inspected and said same U joint is bad. Replaced it with a Moog greasable.
I have a hard time thinking 3 go bad in just over 2 years, when the original OEM lasted 180k + almost 10 years. Thinking something else may be up by mechanics say all looks fine.
Any thoughts/ input?
2008 Hummer H3 Alpha, 205,000km.
Old Nov 27, 2019 | 09:32 PM
the driveshaft might need to be balanced also check the transfercase and differential yoke where they input for lateral play. the bushes might be worn.
Old Nov 28, 2019 | 02:20 PM
Moog and Napa u-joints are manufactured by SKF. I'm a fan of Dana spl and recommend to always replace in pairs.
Old Nov 30, 2019 | 09:09 AM
have driveshaft balanced, replace both front and rear joints with Dana/Spicer sealed joints.
f1ipX
Jun 18, 2017 02:35 PM
H2Miami
Mar 19, 2017 01:09 PM
jman1335
Oct 20, 2016 10:24 AM
H2Miami
Nov 13, 2013 07:15 AM
Songman
Jan 20, 2011 03:51 PM
