Removing Center Dash Fan Vents
Old Jun 3, 2022 | 10:44 AM
echopark's Avatar
Default Removing Center Dash Fan Vents
Is it possible to separate the center dash fan vents from the silver fascia? I can't tell if it's a strange tool, glued, or soldered together. Does anyone know? Has anyone separated it?
The reason is to upgrade the fascia with one that has a bigger opening so that it can take a larger screen.
Old Jun 3, 2022 | 11:13 AM
Pretty sure it is intended to be permanently attached via form melted plastic rivets.
Old Jun 3, 2022 | 04:04 PM
Yes it's possible, with Xacto knife, soldering iron, drill bit, etc. Question is, how are you going to reattach? Another question, where are you mounting the TC selector switch unit & HVAC control unit?
Old Jun 3, 2022 | 09:33 PM
Old Jun 5, 2022 | 01:30 PM
echopark's Avatar
Oh mounting the TC Selector and HVAC control is no problem. My issue is simply separating the fan vent section. I kinda found a youtube video where he said he "cut them off" and then super glued it back. I suppose that's where the xacto knife and soldering comes in.
Old Jun 5, 2022 | 06:19 PM
I don't see room for opening? Center dash panel is already packed full.
dhedrick87
Jul 14, 2020 10:23 AM
Gdraft
Jun 19, 2017 10:01 AM
Damneck
Feb 15, 2012 12:01 PM
Steve #1
Jul 28, 2008 11:42 PM
dilo2001gt
Nov 14, 2006 04:24 PM
