Rear Seatbelt Stuck!
Old Jan 30, 2020 | 06:35 PM
dwaddsy1's Avatar
Default Rear Seatbelt Stuck!
Hello!
Does anyone know how to fix a stuck seatbelt? It is the rear left passenger seat belt. It is fully retracted (how it normally sits) and when I go to pull it out it is locked. I tried many many times to work it to get it out but no luck. I then looked at the side panels but I am too scared to pull them out for fear they will break (I think they have just those plugs holding them in).
Does anyone know how to fix this?
Old Jan 30, 2020 | 06:45 PM
Old Jan 30, 2020 | 06:50 PM
dwaddsy1's Avatar
Thank you for the link to show how seatbelts work. This link unfortunately does not show how I am to fix the seatbelt and to remove the paneling from the inside of the Hummer.
Old Jan 30, 2020 | 06:55 PM
The link was to show you how they work...Did you try slight rapid pulls on it, tap on it? Or possibly there is something stuck in it? Therefore, you would have to take it apart.
Old Jan 30, 2020 | 06:57 PM
dwaddsy1's Avatar
Yes tried probably a hundred different ways of fast to slow and variables in between. I am looking for help to find a source that shows how to disassemble. Need to find a way to take the interior left side panel off and the seatbelt.
Old Jan 30, 2020 | 07:53 PM
Just looked at mine, since I don't have any rear seats installed. I only see a bolt at the top of the belt mount. Other than that the interior panels are pop and pull.
Old Jan 30, 2020 | 08:16 PM
dwaddsy1's Avatar
thanks thats what I assumed.... I'm actually looking to see if anyone here has a link to or knows how to do this?
Old Jan 30, 2020 | 08:56 PM
You need to research how the interior goes together. Like a snap together puzzle. Pop/pull until you see a bolt/screw.
Old Jan 31, 2020 | 07:18 AM
Broken Halo's Avatar
If you get the retractor out DO NOT DISASSEMBLE IT! There is a clock spring inside and if you remove the spring cover it will take off like a buzz saw and you'll possibly get hurt and never get it back together. Remove it, try pulling hard and releasing the belt several times and see if it frees up (hold the retractor in body position when doing this or the 'vehicle sense' pendulum will cause it to stay locked). If that doesn't work order a new retractor and replace it. Trust me, I was a GM seatbelt engineer for several years.
Old Jan 31, 2020 | 08:48 AM
I guess there is a disconnect between knowing how something works and figuring out how to fix it?
I have an old Pontiac that had a rear seatbelt stick because my nephew (who was 9 at the time) was messing with it. Got over-wound and the teeth got too tight a bite to let loose. Took two small screwdrivers, forced the teeth gear and clutch levers to release, pulled the belt way out, shot the mechanism with lubricant. Works fine, still have that Poncho.
Not the same as an H3 belt, but that is how you force them free.....
