Rear main seal leaking
Old Apr 6, 2021 | 11:58 AM
h3fish's Avatar
Default Rear main seal leaking
Dear H3 owners, I am in a jam wondering if any one could help out.
I took the H3 to a transmission shop for oil leak, on and off for the past 3 months the truck has been in the shop.
The mechanic took the transmission on and off several times, use both factory and after market rear main seals, but it still leaks.
does anyone have experience on this? what parts should they use to fix the issue.
thank you so much
Old Apr 6, 2021 | 12:47 PM
When you go through that much labor, never go cheap on the part. You failed to provide year, model and miles so my suggestion is limited to ACDelco OEM part done by a capable mechanic. The fellow doing your work may not be so capable?????
Old Apr 6, 2021 | 12:55 PM
h3fish's Avatar
Hi, thanks for reply, sorry, year 2006, hummer h3, about 190k to 200k miles. thanks
Old Apr 6, 2021 | 01:39 PM
H3Luxembourg's Avatar
Wrong seal used in my opinion . Go for ACDelco Parts and a better mechanic, if it's only the seal problem, he's done something wrong....
Old Apr 6, 2021 | 04:15 PM
Did they verify the source? Oil leaks at the top of the engine appear to be a rear main leak underneath.
Get yourself a bottle of
dye dye
and
leak tracer light/glasses leak tracer light/glasses
Old Apr 7, 2021 | 05:29 PM
Justinh's Avatar
Hummerz has a great point. Also, can't high engine pressure (because of blocked PCV routes) cause this?
Old Apr 7, 2021 | 06:09 PM
Yes, indeed.
Eurynomestolas
Sep 14, 2020 10:36 AM
Justinh
Apr 14, 2020 01:12 AM
smileynialley
Mar 25, 2013 05:19 PM
dscaberboy
Jan 27, 2008 06:27 PM
danist
Aug 24, 2007 07:18 PM
