Rear leaking some fluid
Old Sep 13, 2020 | 12:35 PM
Eurynomestolas's Avatar
Default Rear leaking some fluid
I was down greasing the rear u joint and notice I have a leak that is starting. Do you think I could just put some rtv over it and hope it seals?
Old Sep 13, 2020 | 12:57 PM
wfturner's Avatar
Looks like rear pinion seal is bad.
You need a new rear seal
Old Sep 14, 2020 | 09:10 AM
Clean it with simple green or soapy water and hit it with a pressure washer. Biggest reason diffs leak is due to overfilling, check the level.
If it keeps leaking, you need a new seal..... trip to the local ring and pinion shop for a rebuild.
Old Sep 14, 2020 | 10:36 AM
X2
Bugly
Jul 26, 2019 06:41 PM
vanzachten
Sep 15, 2014 06:24 PM
brad_E
May 23, 2012 12:50 PM
ctdrl-1
May 10, 2010 11:42 AM
H3_2009
Dec 14, 2009 06:02 PM
