Rear fender clips leaking into rear cargo area
Old Feb 8, 2020 | 02:43 PM
According to this listing (quantity needed 1 per front flare) 1
11562147 11562147
Quantity Needed: 1 per rear flare on this listing:
11562147
Old Feb 8, 2020 | 03:06 PM
Broken Halo's Avatar
No, I think what they're saying is you only get (1) clip per order but more are required. If you re-read they aren't saying (1) REQUIRED, they are saying (1) INCLUDED. If you look there are (7) holes for clips in that front fender picture. There's no way (1) clip would hold that entire fender flare on.
Old Feb 8, 2020 | 03:15 PM
Read both listings again: Quantity Needed:1
Those other holes would require normal push pins. The 11562147 would penetrate the interior, requiring the foam seal.
Old Feb 8, 2020 | 03:20 PM
None of the front clips penetrate the interior but they are showing it for the front fender. I think the same clip is used in each hole location not just to prevent water intrusion but to also prevent squeaks. Maybe the O.P. will chime in and clarify.
Old Feb 8, 2020 | 03:33 PM
The rear of the front flares are mounted next to the interior. Yes, the OP can learn us something.
Old Feb 8, 2020 | 06:27 PM
H3steve's Avatar
Hey guys thanks for all the help,
there are a total of 12 Flare retainer clips 6 per side, 4 clips going horizontal and 2 vertical in the rear pillar
Old Feb 8, 2020 | 07:12 PM
Can you answer this question: How many look like the picture you posted above(11562147)?
Old Feb 9, 2020 | 06:23 AM
If you still have the interior panels pulled could you take a couple of pictures of the sunroof rear drain hoses where they exit the sheet metal (assuming you have a sunroof). Thanks
Old Feb 9, 2020 | 04:02 PM
H3steve's Avatar
Hey guys I can totally take care of this, I'm leaving for work and probably won't be able to do much for a week or two but I will absolutely follow up on this stuff
Old Mar 24, 2020 | 09:28 PM
H3steve's Avatar
Been a bit busy finally got around to taking the flare
There are 6 clips in total
4 White plastic clips = part #3
2 Grey plastic clips = part 29
I have no idea why GM used 2 different part numbers maybe someone here can enlighten us with a good reason.
My fix to the leaking is for now some really soft o rings from mcmastercarr, hopefully is it a better fix than the crummy foam that was used?
HumbleAg
Jan 23, 2019 07:19 AM
PhilB
Feb 2, 2015 11:22 AM
DDNGUY
Sep 23, 2011 10:44 AM
veves
Aug 18, 2009 06:52 PM
gregaac
Jan 19, 2009 09:22 PM
