Rear brake caliper bracket bolt
Old May 29, 2020 | 09:50 PM
asjohnson81's Avatar
Default Rear brake caliper bracket bolt
Hello. I’m desperately trying to find a rear brake caliper bracket mounting bolt for the rear drivers side. I have a part number for it (GM11589201) but it’s a discontinued part and I can’t find it anywhere. Was anybody able to find one or know of a different bolt that will fir? It’s for a 2007 h3
Old May 30, 2020 | 09:43 AM
Old May 30, 2020 | 11:02 AM
Thats the guide pin kit. I’m looking for the caliper bracket mounting bolts
Old May 30, 2020 | 11:26 AM
Check your local diy or hardware store..
11589201: M12 X 1.5 6G X 28.5)(08.900).
Menards>M12 x 1.5 x 30mm class 10.9
Old May 30, 2020 | 03:54 PM
wfturner's Avatar
As you know this is an out of stock item and sorry, but your local hardware store won't carry fine thread bolts in 12MM l;
When I replaced my rear brake carrier bolts as prescribed by our service manual I went here . . .
https://www.belmetric.com/m12x15-fin...208_1223_1995/
I ended up getting the longer bolt and cutting it to 28MM length
or you can use the 25MM length and these are flange bolts
Old May 30, 2020 | 04:35 PM
I do not recommend going shorter, more threads stronger hold. 30mm length with a washer would be close to oem length.
Old May 30, 2020 | 04:41 PM
wfturner's Avatar
Agreed, that is why I went to 40MM length, but you are much better using a flange bolt
Old May 30, 2020 | 07:01 PM
I had to go the hardware store to find them. The mail would take too long to get here and I need the vehicle. I did save that website for the next time I need something though. I appreciate all the input
sturm
May 11, 2020 03:16 PM
cvendel
Aug 11, 2019 08:09 AM
lhinton1
May 16, 2015 07:23 AM
BaseballJones
Sep 26, 2014 05:49 PM
therealtimtaylor
May 11, 2012 10:20 PM
