Rasping/grinding noise when turning and accelerating
Old Jul 23, 2019 | 09:43 AM
Sinclair's Avatar
Default Rasping/grinding noise when turning and accelerating
Currently ive been having an issue when turning, not only is my wheel feeling stiff but i also get a grinding or rasping noise on occasion when turning under acceleration.
My thought is possibly the wheel bearings or CV axel?
Old Jul 23, 2019 | 09:47 AM
Are you stuck in 4Hi Lock. When was the last time the T Case fluids and Diff lubes were changed?
Crawl under and do a visual inspection of the Half Shaft boots to look for tears or leaking grease.
Have you adjusted your Torsion Bar Keys at some point and went too far so that the front sits higher than 23.5" from fender lip to hub center?
Old Jul 23, 2019 | 10:22 AM
Sinclair's Avatar
I dont think i am in 4hi, but i will look.
I am a new owner, and the T case fluids were just done. I am thinking it is something to do with my boots as it only occurs when turning right.
Thanks for the leads.
Old Jul 23, 2019 | 11:56 AM
Sinclair's Avatar
The vehicle was in 4Hi lock, since changing it the noise has subsided considerably.
Thanks for the advice, im still going to have a long look underneath when i get time this weekend
Old Jul 30, 2019 | 09:10 AM
Sinclair's Avatar
Issue resurfaced and then resolved again.
Culprit was Loose a heatshield on exhaust piping, bolt was missing.
thanks for the Advice!
Kirkhayes37
Feb 4, 2014 04:01 AM
vacman
Apr 4, 2013 01:09 PM
BERULAKIDE
Nov 24, 2012 09:51 PM
zefrum
Hummer H3T
Oct 19, 2012 02:27 AM
lancevallery
Apr 13, 2010 06:53 PM
