Rack and Pinion Movement
Old Dec 11, 2011 | 02:20 PM
screaminhd's Avatar
Default Rack and Pinion Movement
How much movement should rack and pinion have with bushings that appear to be in good condition. Only 20k miles. Any input appreciated. Thanks.
Old Dec 18, 2011 | 10:02 AM
thedave8's Avatar
I would say there should be no slop in the rack to frame bushings, howerver my 07 H3's passenger side bushing does have some lateral motion on a lift ,suspension hanging.....when you wiggle wheel left to right ....needs a poly bushing in my opinion
Old Dec 18, 2011 | 11:42 AM
2wheelmonster's Avatar
I agee with thedave8, I have 67k on mine and not much play at all. I do some offroading but nothing extreme
Old Dec 18, 2011 | 05:28 PM
Hunner's Avatar
The Problem (click this one for video)
The Solution;
Old Dec 18, 2011 | 10:01 PM
Hunner, I was waiting for you to see this post and post your video and some pix!
perfect
Old Dec 19, 2011 | 05:30 PM
HawaiianH3's Avatar
I love this DIY job! I ended up loosening mine and sticking some "make your own gasket" material in there. Its worked thus far but only a temp fix. Hunner you got the "slam dunk" with this build!!!!
Old Dec 19, 2011 | 06:56 PM
screaminhd's Avatar
Thanks for all the input. I had the GM dealer check it over after alignment shop said it needed new bushings. Dealer said everything was tight. I brought it home and had my wife turn steering wheel back and forth while I looked at rack. Passenger side bushing had some movement, but through bolt on driver side had enough slop to allow rack to make knocking sound. Took it back to dealer, showed them what I found and they agreed, ordered new rack, and replaced it. I found out that when they checked it, they only checked it up on lift. Which showed things were tight. Only when loaded with weight could the slop be seen.
Old Dec 19, 2011 | 08:48 PM
Hunner's Avatar
I couldn't stand it any longer and even though like 999 got boring I thought I would respond. It seems that you have to find the right place to find the slack. Sometimes when on the ground it gets in a place that it is not in a bind and will move or sometimes when jacked up you can do the hands behind the tire and one in front and push pull to see it move. After awhile it can loosen the other end by flexing those rubber inserts OR break the rack. I still have a few of the sleeves left that are two inches long to fit between the OEM tie rod boots and the hydraulic nipple.
This shot is with my BP tie rods and I made some boots. This was before I trimmed the extra threaded bolt on the clamp, as once I do it will be too short to reuse. It was just the only shot I could find right now.
The ultimate fix would be to add a center bracket to help hold the thing in place.
Old Feb 22, 2012 | 10:28 AM
wortex's Avatar
It looks good but with being a solid metal instead of a flexible rubber/poly, isn't it effecting anything on the steering ? It might scratches the rack as the rack flexes, but otherwise it is fine ?
What is the diameter of the rack ? Can I use something like a Rod bearing there if the thickness is correct ? If I use a good lithium grease, will that work ?
Old Feb 22, 2012 | 09:58 PM
58Bisc's Avatar
Hummer, how much for a set of selves? I'm interested and I have PayPal! Lol I'be been eyeing up a new rack with 16 mm tie rod ends for $200.
