Problems with Fuel pump wiring
Old Jan 31, 2023 | 02:52 PM
Luka's Avatar
Default Problems with Fuel pump wiring
Hi.There's something wrong with the electrical wiring in my car - H3. The fuel pump gets power even when the key is turned off. Currently the fuel pump is burnt out due to this. Could you please advice, how to find a fault and solve the problem?
Hi. There's something wrong with the electrical wiring in my car - H3. The fuel pump gets power even when the key is turned off. Currently the fuel pump is burnt out.Could you please, advice, how to find a fault and fix the problem?
Old Jan 31, 2023 | 09:23 PM
Car?
Old Feb 1, 2023 | 05:57 AM
Fuel pump relay stuck open?
Drop the fuel tank and take a look at all the wiring there. You are going to have to drop the tank anyway to replace the fuel pump.
If the issue isn't in that location you will need to follow the wire loom looing for issues.
Old Feb 1, 2023 | 10:22 AM
Merged and Moved. Welcome. All H3 questions go in the H3 section.
HumH3Buff
Apr 20, 2020 01:29 PM
wkrpinnick
May 27, 2012 10:17 PM
SuperH1
Jul 12, 2011 10:45 AM
blackdragon
Jun 29, 2011 07:22 AM
dscaberboy
Sep 26, 2008 10:11 PM
