Power Locks Stopped Working
Old Oct 8, 2021 | 07:28 AM
OutlawJesseJames's Avatar
Exclamation Power Locks Stopped Working
2006 Hummer H3
Both Power Locks have stopped working. I can't open the tailgate. The windows both work fine. Suggestions?
Old Oct 8, 2021 | 02:08 PM
Originally Posted by OutlawJesseJames
2006 Hummer H3
You still using the OEM Crappy Azzed Battery Terminal connectors?
Old Oct 8, 2021 | 02:48 PM
Yeah, as far as I'm aware the've never been changed.
Old Oct 8, 2021 | 06:21 PM
This happens when the battery voltage gets low or if the battery has been disconnected. The computer is programmed to turn off some of the electrical items when low voltage is detected. It usually starts with the windows and locks.
Old Oct 8, 2021 | 07:00 PM
This would make the most sense. I often leave the car on for long periods of time. Should I replace the the terminals or the whole unit?
Old Oct 8, 2021 | 07:23 PM
Start by checking with a multi-meter, check resting voltage on the battery, then check at the mega fuse compare look for a voltage drop at the fuse block. Post your results.
Old Oct 12, 2021 | 03:03 PM
The OEM Battery Terminal Connectors are JUNK, Garbage, trash, and ALWAYS fail, just a matter of time. #1 mod to be dine to every H3/H3T. Replace with Stingers or your favorite brand. Search it out, here and on the web.
Autobot85
Feb 1, 2022 05:58 AM
A-Rock
Jan 8, 2013 02:19 PM
smith288
Apr 6, 2011 10:44 AM
General
Jun 3, 2008 07:39 PM
juanillohummerh2
Jul 18, 2006 12:04 AM
