..:: The plate light situation ::..
Old Jun 29, 2025 | 05:57 PM
Oreofudge's Avatar
Default ..:: The plate light situation ::..
Hi Guys!
Plate light on a 2K7 H3 Base is not working, one of the wires of the connector had been pulled out completely and there seems to be no way to put it back in, so I'm looking for that connector to replace it and then be able to hook it up back to the light fixture. Bulb and light fixture seem to be ok, is just that one wire pulled out, so no power. Any help finding the right connector will be appreciated, thanks!
Old Jun 29, 2025 | 08:11 PM
Oreofudge's Avatar
Nevermind guys, I think I found it in Partgeeks -License Lamp Connector (19076-02207154) from AC Delco. Thanks.
Old Jun 29, 2025 | 08:56 PM
2007 hummer h3 bulb replacement chart
2007 Hummer H3 Bulb Replacement Chart
For Hummer H3 2006 2007 2008 2009 2010 Combo LED Headlight ...
Here is a breakdown of the bulb sizes for the 2007 Hummer H3 based on the provided search results:
Exterior Lighting:
  • Headlights (High Beam and Low Beam): H13 (9008) OR H4 (9003 HB2)
  • Front Fog Lights: 9145 (H10 9140)
  • Brake Light (Rear): 3157 (3156)
  • Daytime Running Light (DRL): 3157 (3156) or 7440/7443
  • Parking Light: 3157 (3156)
  • Reverse Light (Back-Up Light): 3157 (3156) or 7440/7443
  • Side Marker Light (Front): T10 (194 168)
  • Side Marker Light (Rear): T10 (194 168)
  • Turn Signal Light (Front): 3157 (3156) or 7440/7443
  • Turn Signal Light (Rear): 3157 (3156) or 7440/7443
  • Tail Light: 3157 (3156)
  • License Plate Light: T10 (194 168)
Interior Lighting:
  • Courtesy Light: T10 (194 168)
  • Dome Light: 211-2 (578 41MM)
  • Luggage Compartment Light: 211-2 (578 41MM)
  • Map Light: 211-2 (578 41MM)
  • Trunk Light: 211-2 (578 41MM)
  • Ash Tray Bulb: 192
  • Instrument Panel Light Bulb: 1HNS89 (1.2 Wattage)
Important Notes:
  • Some exterior lighting applications, such as turn signals and DRLs, may have alternative bulb options (e.g., 7440/7443), particularly when considering LED upgrades.
  • When replacing bulbs, especially turn signals with LED bulbs, you might need to install load equalizers or an LED flasher to prevent "hyperblink" (fast flashing).
  • Diode Dynamics states that their LED turn signals are a direct replacement for the factory 3157 bulbs.
  • It's recommended to replace bulbs in pairs to ensure equal brightness and color.
  • When handling halogen bulbs, avoid touching the glass with your bare fingers.
Old Jun 30, 2025 | 09:32 AM
Oreofudge's Avatar
Thanks HUMMERZ for the great write-up!, greatly appreciated! ;-]#
BigStrip
Sep 8, 2023 08:32 PM
Dark Abyss
Apr 10, 2022 12:40 AM
pkhinno
Jun 3, 2019 03:03 AM
hairco
Jun 3, 2012 05:40 PM
PJ H2 SUT
Aug 15, 2009 12:09 AM
