Persistent squeal- help
Old Nov 28, 2019 | 03:50 PM
jman1335's Avatar
Default Persistent squeal- help
I have been through three mechanics and a number of repairs to try and figure this out.
ROTATIONAL SOUNDING squeal, sounds like front wheel is where coming from.
first mechanic said was belt and idler tensioner, replaced. No difference. Sent it back then it was front u joint loose. No difference and Sent it back. Said then rear u joint (even thought it was only 3 months old), replaced and no difference. It’s a LOUD noise I can’t figure out HOW he didn’t identify that.
so frustrated went to a new mechanic. Said it was pitted rotors and replaced front brakes and serviced (cleAned rears). NO DIFFERENCE.
i can’t believe no one can figure out this loud rotational squeal.
any suggestions from anyone?
2008 H3 Alpha, 206,000km
Old Nov 28, 2019 | 04:29 PM
How much did you pay to your 3 mechanics?
Old Nov 28, 2019 | 05:24 PM
jman1335's Avatar
Too much...its so hard to find a good mechanic where I am...
Old Nov 28, 2019 | 08:02 PM
Where are you at? Post your shops....there's a worldwide system in place.
Old Nov 30, 2019 | 08:59 AM
Squeal in the front @ the wheel/tire is usually the hub assembly bearing.
Do you have movement when grabbing the tire @ 12 and 6 o'clock?
Old Dec 2, 2019 | 07:44 AM
choochmalooch's Avatar
Cool
If you have chrome wheels look at the inside of your wheels. When the chrome starts to peel it sometimes peels back in large chunks and rubs as the wheel rotates causing a squealing sound. I chased this problem for several weeks before I found it. There was 5" square piece of chrome peeled back that rubbed as the wheel rotated.
patspano
Aug 15, 2023 09:19 PM
ninjarider
Mar 29, 2015 05:24 PM
Jack America
Jan 23, 2013 08:18 AM
bosch
Jan 10, 2013 05:52 AM
t_dog_lxi
Aug 9, 2012 05:19 PM
