Parking Brake Handle Breaks off...
Old Jul 10, 2020 | 09:09 PM
H32006's Avatar
Default Parking Brake Handle Breaks off...
Pulled it as always, but this time it came out in my hand.
Looks like the plastic inside is broken off.
How hard is this to fix myself?
I see the part is like $6.
Old Jul 13, 2020 | 07:13 AM
Nothing looks broken to me. Push it back on. You will hear it snap into place.
We have had 7 H3/H3Ts they have ALL come off at one time or another.
Truthfully, pulling hard on it is the only way to remove them from the cable too.
Old Jul 13, 2020 | 12:43 PM
It is supposed to come off when you over-pull it..... Like Taint said, so you can replace the cable if needed.
Old Jul 13, 2020 | 06:43 PM
Broken Halo's Avatar
There's a tapered 'clip' that's part of the cable that goes into the handle. The handle has a little window type opening on each side that the clip snaps in to. I have a clip removal tool that works perfectly to reach into the little windows and squeeze the clip to release the handle with out doing any damage to it.
Old Jul 18, 2020 | 09:28 PM
H32006's Avatar
There is a piece in there that is moving. Looks like the end of the cable part.
Just purchased a new handle and new cable.
Old Jul 18, 2020 | 09:35 PM
H32006's Avatar
It appears I could salvage the handle as I got the broken pieces out.
It is the tip of the cable plastic that broke inside the handle, so it is the cable that needs to be replaced because of the broken plastic tips that interlock into the handle.
How do I replace the cable? Any advice on what to do? I am blind on this.
Thanks for the help all!
Old Jul 19, 2020 | 11:08 AM
Old Jul 19, 2020 | 11:29 AM
I use a 13mm 12pt box wrench to release retainer from mount(#4 in pic above).
cable 25792420:
Amazon Amazon
Lisle 40750 Parking Brake Cable Remover:
Old Jul 19, 2020 | 11:53 AM
Scratch that, I just looked at mine, looks like a small wing clip, compress with needle nose pliers to remove. You should be able to remove this cable in 5minutes. Just make sure all the other cables are free before you break it again. GL
cesar23w
Hummer H1
Aug 2, 2020 05:05 PM
DOM T
Feb 21, 2011 06:56 PM
DsH308
Aug 14, 2008 12:14 AM
JWSchmidt3
Jun 2, 2007 12:57 PM
