P0717 code
Hello ,I really want to thank everyone for helping me getting this thing running again. I have a 2007 hummer h3 and I recently got p0717, shifting acting up. I looked up the code it’s the transmission input speed sensor, I found the right part at a local store. I made a research and some people said might be shorten or dirty because of the elements etc. I am trying to find it and I can’t see to find it. Online they say it’s in the passenger side next to the transmission put can’t find anything!! Can you help me find it or send me pics so I can check out?
thank you |
(Post 314506)
At the plug to the transmission, check for 12 volts on pin E Pink wire.
Ground on the pin V Light Blue. Verify pin K Brown/White wire is not open or shorted back to the Powertrain Control Module (PCM) Blue connector pin 23. If all the above is OK with everything plugged in, backprobe the Brown/White and check for square wave signal with the engine running. If no signal is present, then replace the input speed sensor. To replace the input speed sensor requires removal of the transmission and then removal of the front pump from the transmission assembly. GL https://cimg7.ibsrv.net/gimg/www.hum...2e2b207a70.jpg https://cimg6.ibsrv.net/gimg/www.hum...1b7a0c543c.jpg |
(Post 362460)
https://cimg6.ibsrv.net/gimg/www.hum...1b7a0c543c.jpg Where can can I find this plug that have all those wires to check them? |
Originally Posted by NFS
(Post 362462)
https://cimg7.ibsrv.net/gimg/www.hum...2b034a5232.jpg https://www.autozone.com/repairguide...96b43f81b3c7c4 |
(Post 362463)
on the trans...
https://cimg7.ibsrv.net/gimg/www.hum...2b034a5232.jpg https://www.autozone.com/repairguide...96b43f81b3c7c4 Ok i I unplugged it but how you know which color is which? And how to test it on the voltmeter? Sorry I am not good with electricity https://cimg7.ibsrv.net/gimg/www.hum...7a6e5016a.jpeg |
(Post 362463)
on the trans...
https://cimg7.ibsrv.net/gimg/www.hum...2b034a5232.jpg https://www.autozone.com/repairguide...96b43f81b3c7c4 Is there a chance that something got lose inside the pan because the shop dropped the pan not that long ago and did transmission fluid and I noticed that plug plugs just above the pan so I was wondering if something got lose is that possible ? |
(Post 362468)
Here's a pic of the harness inside: https://cimg4.ibsrv.net/gimg/www.hum...71bc3657db.jpg |
(Post 362489)
Doubtful, but anything is possible, however you need to drop the pan to check(I have in the past found pinched wiring between the pan and housing causing an issue). In the meantime test the signal to the pins as I posted above.
Here's a pic of the harness inside: https://cimg4.ibsrv.net/gimg/www.hum...71bc3657db.jpg I have all those codes P0976 P0717 P0787 P0973 P2769 P2764 I also made another thread about that :( is my transmission dying? |
It still points to the ISS, you NEED to check with multi meter, without the p0717 there is a TSB:
https://f01.justanswer.com/heavy_che...44_P1860+2.pdf |
