p0420
Old Aug 18, 2020 | 12:55 PM
afiqimanov's Avatar
Unhappy p0420
Dear All,,
How can I fix this problem:
p0420: catalyst system efficiency below threshold bank 1
Old Aug 18, 2020 | 01:10 PM
Replace the catalytic converter.
Old Aug 18, 2020 | 01:22 PM
afiqimanov's Avatar
Do you mean change catalytic completely ?
Old Aug 18, 2020 | 01:37 PM
If there are no other problems, Replace. How many miles on it?
"Some suggested steps for troubleshooting and fixing a P0420 error code include:
Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady). Inspect the downstream heated oxygen sensor, replace if necessary
Replace the catalytic converter"
Read more at: https://www.obd-codes.com/p0420
Old Aug 18, 2020 | 01:43 PM
afiqimanov's Avatar
92000 km
Old Sep 4, 2020 | 09:51 AM
V8-H3's Avatar
I replaced my cats but with magnaflo cats and new O2 sensors and still have the code.
The O2 sensors don't like the after market cats and I wasn't about to pay the GM price and 30 day wait to get them.
Now to come up with a fix for the after market cats throwing codes on my Alpha.
Old Sep 4, 2020 | 10:51 AM
gpcalero's Avatar
One easy way to do it is to get the truck tuned. They can turn the rear O2 sensors off. If you live in a state that tests emissions, may not be an option for you though.
That's what I did, no cats here.
Old Sep 5, 2020 | 12:33 PM
V8-H3's Avatar
Thanks, I'll have to check into that since we don't have emissions testing here in Florida.
Old Sep 8, 2020 | 09:55 AM
Did you clear the code after replacing the Cats? Did you use ACDelco O2 sensors?
Old Sep 9, 2020 | 09:04 AM
V8-H3's Avatar
yes to both. It comes back next time the engine is started each time. Will stay off until then too.
