P0300 Engine Misfire Detected
Old Nov 8, 2020 | 06:06 PM
Sean Gamble's Avatar
Default P0300 Engine Misfire Detected
So I keep getting a P0300 Engine Misfire Detected. I replaced all the plugs and coils with original AC Delco ones. I'm also getting a P0455 Gross EVAP Leak but I believe that was fixed by replacing the purge solenoid. Now when I removed the air cleaner resonator to replace the plugs and coils I noticed that the PCV hose was cracked and split so that has been replaced. So after all that I hooked up my handy Tech 2 to look at the misfire data. It's mostly #2 that is misfiring but all of them misfire at some point but it only misfires when idling. I drove down the road and the engine was at 2000 RPMs and it didn't hiccup but as soon as I stopped at a light it's misfiring. What else could be causing it?
Old Nov 8, 2020 | 06:38 PM
P0300 + P0455=
Old Nov 9, 2020 | 02:42 AM
P0300 + P0455=
A rusty fuel pump is the answer?
Old Nov 9, 2020 | 05:15 PM
When rusted through! Do you have a gas/fume odor? Check the top of the FPM.
Old Nov 10, 2020 | 12:10 AM
I checked and it shows a little sign of wear but not much. I'm not smelling any gas fumes at all when running. Even if that was the problem why would it only occur at idle?
Aaajaws
Feb 9, 2020 08:49 PM
robthomas16
Sep 13, 2019 10:46 AM
swampdawg
Sep 7, 2015 09:43 PM
Dingeray
May 19, 2013 02:28 PM
crazybizzle
21
Aug 19, 2012 01:55 AM
