Only reverse gear
Old Feb 18, 2020 | 08:02 PM
staggs's Avatar
Default Only reverse gear
I've got an 08 H3 with 120k miles. Today I was driving down the highway just fine, went to pass someone and once the auto trans shifted down to pass it increased briefly then I just lost all forward gears. No sound that I heard, nothing just went from driving to acting like it's in neutral. I coasted to the side of the road and stopped. Tried restarting numerous times, tried sifting through all gears, tried shifting the tcase through all and nothing except reverse works fine.
A few months ago the rear driveshaft went and I had to replace it along with the diff u joint ajar shaft. Once I put the driveshaft and everything back together and went to pull out of the garage it wouldn't shift into gear at first, made a horrible sound a couple times, then went into reverse just fine and has been driving prefect ever since.
I have no codes, no warning lights. Haven't looked at the fluid yet since it was dark out but the tcase is brand new fluid.
Old Feb 18, 2020 | 09:23 PM
Check fluid level, running at operating temperature.
Old Feb 19, 2020 | 10:32 AM
Two options:
1) Get a BIG rear view mirror and drive backwards everywhere... cops will not like it; or,
2) have a rebuild done to your transmission.
Check the trans fluid on a level surface with the engine running at operating temp per above. Is it dark, smell burnt, too low????
Old Feb 19, 2020 | 04:07 PM
staggs's Avatar
Two options:
I just got home (i actually did drive it home in reverse, it broke down on the side of the road about 5 miles from my house, had no issues) checked fluid and it's not low, it is on the red tinted black side so I know it's definitely in need of a fluid change.
Old Feb 19, 2020 | 05:50 PM
First drop pan and inspect, probably to late for fluid change.
Old Feb 20, 2020 | 12:16 PM
wpage's Avatar
Agree, you may find a few unexpected items in your pan.
May be time to see the trans shop.
stacyd
Feb 13, 2020 09:16 PM
ketchikanmd
Oct 18, 2018 01:20 PM
ProphetPVD
Jan 11, 2017 03:45 PM
Tony525
Mar 2, 2015 11:21 AM
carolympus
Sep 20, 2013 07:17 AM
