Old spark plugs 107k
Old Nov 12, 2019 | 08:11 AM
Eurynomestolas's Avatar
Default Old spark plugs 107k
So I don’t know much about spark plugs but did I do the right thing and change them?
Old Nov 12, 2019 | 08:17 AM
Sam!'s Avatar
Yes those look plenty worn!
Old Nov 12, 2019 | 09:18 AM
Ok cool glad to know. Do they just get rusty looking over time? Or is that because the coil packs weren’t sealed properly?
Old Nov 12, 2019 | 12:56 PM
As long as you replaced them with the correct OEM Iridium Plugs it should be all good.
iridium plugs should last 100k+.
those are most likely the originals so i am sure some rust will develop.
Old Nov 12, 2019 | 05:49 PM
Sam!'s Avatar
The corrosion on the threads is water/moisture getting down through the outside. antisieze would prevent that, on the electrode its the wear from arching pitting and from being in the combustion chamber.
Old Nov 12, 2019 | 06:25 PM
Take another look. The moisture is coming up from the engine!
Old Nov 12, 2019 | 11:11 PM
like Hummerz suggests that's what happens with older low milage vehicles that spend most their time sitting. they need to be driven to keep moisture at bay.
Old Nov 13, 2019 | 08:01 AM
choochmalooch's Avatar
Cool
I know with newer engines they say you can go 100K miles on a set of spark plugs but I always felt uncomfortable leaving them in that long. I change mine after 50K. Might be a waste of money but it gives me piece of mind.
Old Nov 13, 2019 | 08:57 AM
As a new h3 owner around here. I just wanted to say thanks for all the comments and support. I know that I made the right decision changing them.
Kkneat
Dec 26, 2016 06:18 PM
Aries5998
Dec 11, 2015 02:00 PM
StephenOSU
Sep 26, 2012 07:09 AM
drc420
Apr 19, 2011 09:24 AM
LGK
Oct 27, 2010 08:13 AM
