Oil pump replacement
Old Feb 8, 2020 | 03:45 PM
roadfire's Avatar
Default Oil pump replacement
06 H3,, low oil pressure at idle, already changed sensor with OEM, Using the correct oil and filter just changed. sending the PCM to get idle raised, if this doesn't correct it I am planning on Oil pump and pressure spring replacement.
My question is: is it necessary to pull engine to remove oil pan? is there a link to step by step process to doing this?
Old Feb 8, 2020 | 03:51 PM
Originally Posted by roadfire
sending the pcm to get idle raised,
wtf????
Old Feb 8, 2020 | 05:46 PM
roadfire's Avatar
Probably didn't word it right.sending the PCM to get idle speed increased by about 100 rpm. read on other forums this has helped the oil pressure light from coming on at idle, cant seem to find any more definitive fix
Old Feb 8, 2020 | 05:54 PM
Current idle?
Old Feb 8, 2020 | 05:58 PM
roadfire's Avatar
about 550 i while in drive with foot on brake, tap gas pedal light goes out and beeping stops, fairly smooth, the MAF and throttle body has already been cleaned, this problem just started.
Old Feb 8, 2020 | 06:05 PM
I don't get low oil pressure @550! What oil are you using?
Old Feb 8, 2020 | 06:10 PM
roadfire's Avatar
Quaker State 5w-30
Old Feb 8, 2020 | 06:56 PM
back in the day, it was considered quaker shale,,, I've never used it.
Try this:
Engine flush(15minutes) then change oil/ filter.
step 1:
Pour into engine, then run engine for 15 minutes, then turn engine off, and drain oil, wait another 15minutes to drain, while you are waiting, replace the filter:
Then fill with 6qts of recommended oil:
Then post your results.
Old Feb 8, 2020 | 07:01 PM
roadfire's Avatar
I will try this. However I have been using Quaker State 5w 30 for about 60,000 miles with zero problems, but I'm always open to suggestions, I will try it.
Old Feb 8, 2020 | 07:31 PM
Get to the source before you cause engine failure!
