oil light and constant warning chime
Old Aug 10, 2020 | 07:22 AM
choochmalooch's Avatar
What’s the mileage? Mine started doing the same thing at about 142k miles. Cleaned the throttle body and changed my oil sensor then rpms came up just enough at idle that my oil light went out. Everything was good unless the engine saw hotter temps, like in heavy traffic with the a/c running or at idle when towing. Then the light would come on. If I touched the gas and raised the rpms just a touch it would go out. Sidebar to this I also have been noticing a drop in gas mileage and my Hummer now seems to down shift more often when climbing steep overpasses on the interstate. I think the I5 is just getting “tired” from the high mileage and all the towing I’ve done over the years.
Old Aug 12, 2020 | 08:03 PM
lostsoul77's Avatar
I think im at approximately 165,000 It's doing EXACTLY what you just described. I cleaned the throttle body, MAF sensor, replaced oil switch, replaced intake and exhaust solenoids, cam sensors. My temp does tend to run on the high side as shown in the picture so I'm wondering if I have a thermostat going bad or oil pump.
Old Mar 20, 2022 | 10:15 AM
VICTOR_h3's Avatar
Originally Posted by lostsoul77
yes..oil level is in range
what was the solution to that problem
Old Mar 21, 2022 | 10:53 AM
We would appreciate it if you would AVOID digging up OLD Threads to tack a question on the end.
Maxine Rennspies
Mar 4, 2020 12:55 PM
rachelellis
Feb 9, 2020 11:04 AM
Mr B
16
Dec 26, 2017 11:35 AM
ImNoSaint
Feb 11, 2014 11:50 PM
