Oil alert
Old Jun 17, 2023 | 08:38 AM
sean4570's Avatar
Default Oil alert
I was about 500 ft from home yesterday when the warning tone and the oil symbol appeared in the instrument panel and oil appeared on the speedo. it then went out when I got home I checked the oil ant it was full ( I added a quart last week).
Any one have idea what might be going on?
Old Jun 19, 2023 | 08:37 AM
None, not any because you posted in the generic forum section and did not provide Year, Model or Miles.
Old Jun 19, 2023 | 10:10 AM
sean4570's Avatar
It is a 2008, 195,000 miles, is a H3
Old Jun 19, 2023 | 11:18 AM
Millertime045's Avatar
I’m 06 with same miles lol the oil dinging light it’s nightmare took me 4 months and 2000 get it fixed finally 🤣
Old Jun 19, 2023 | 12:32 PM
Could be simple, like a bad pressure sending unit or a failing oil filter. Could be nasty internal damage or blockage. I would start with the east stuff. When was the last time the oil & filter were changed and what oil and filter are you currently using?
Old Jun 19, 2023 | 12:44 PM
sean4570's Avatar
I had the oil changed in early April just before a 1600 mile round trip to NJ. I do not know what brand but weight is 5w-30.
Millertime045 what was the reason and how did you solve it?
Old Jun 19, 2023 | 11:00 PM
i did everything motor flush, switch to ac delco oil filter,use Mobil recommend oil, changed 3 different oil sending units, had oil compression test done like 5 times threw out 2 different shops , and finally I think had oil sending unit switch plus pig tail changed mine they said ended up after alllll that being low oil pressure & oil pump and pickup tubs replaced 1600 in that alone I’m at 1700 miles since it snd knock on wood it’s not digging anymore me if I was you start with oil compression test but I’m not gonna lie was nightmare and major headache finding out issue
Old Jun 20, 2023 | 05:25 AM
sean4570's Avatar
Thanks for the info, I have something to look forward to
Old Jun 20, 2023 | 08:26 AM
Oil Pump Pickup Tube O-Ring $14.30 and most of the day getting to it to R&R. It pays to wrench on these thing yourself.
Old Jun 20, 2023 | 01:54 PM
sean4570's Avatar
Is there a you tube video on the replacement? How hard is it to get at.
I was going to replace the valve cover gasket until I watched what was involved on you tube
