Mufflers
Old 12-13-2013, 09:07 AM
stevelnew's Avatar
Default Mufflers
Is there a "prefered" single inlet to dual tip exhaust muffler out there for the H3? (3.7 or 3.5)
Old 12-13-2013, 02:25 PM
stubbsy's Avatar
I had a Magna Flow on my 3.7 it droned really bad at highway speeds so I took it off and had a custom system made with full stainless mufflers.
Old 12-15-2013, 05:21 PM
Nmocean's Avatar
I have the magnaflow duel outlet cat back on mine it not loud or drones at all
Old 12-17-2013, 11:59 AM
ollied's Avatar
Default Muffler
I removed my orig muffler, cut a 2.5 hole in rt side & welled in a 90 elbow . Sounds great 07 h3 x, red,, lited 2.5 dual battery chip.
Old 12-17-2013, 01:46 PM
Songman's Avatar
I'm interested in dual outlets, better sound, and freer exhaust too. It seems that an awful lot of it is subjective here on the forum... like the two totally different experiences with Magnaflow above. My question is, what exactly does a catback include for the H3 since the cat is in the exhaust manifold? Is it the complete exhaust?
Old 12-17-2013, 02:14 PM
I5 H3s have a mini cat in the exhaust manifold, and another rear cat BEFORE the resonator, which is before the over axle pipe to the muffler.
LH8 H3s have three, a mini in each exhaust manifold and another at the rear behind the Y pipe.
The cat back systems start...... yep, at the rear cat back.
Rear Cat Alpha
Old 12-17-2013, 02:21 PM
I've had my MagnaFlow cat back since June 07, sounds great. If you never bought a CAT back system, they take a good 1500- 2000 miles or so to break in and mellow tone. Mandrel benders use inside and outside pipe manipulation and require tooling oil to stretch and bend the pipe so the machine does not deform the pipe, that takes time to burn off, while clamps are seating and the muffler is being broke in. Relax, enjoy the sound.
Old 12-17-2013, 02:22 PM
Songman's Avatar
Ahhh.. I didn't know about the rear one. Thanks Doc.
Old 12-18-2013, 09:15 PM
NJTEX's Avatar
Go Solo! Performance Exhaust Systems | Performance Exhaust
They're the best that I've ever found for my Pontiac.
Old 12-21-2013, 03:27 PM
HUM3LE's Avatar
I like mine. Its a borla cat back kit for my 3.5 L. Car id.com is where I ordered through.
Quick Reply: Mufflers
