Mayhem Metal Works Steering Rack Kit
Old Feb 2, 2024 | 08:33 AM
Tony-Nav's Avatar
Default Mayhem Metal Works Steering Rack Kit
Has anyone had any experience with Mayhem Metal Works Hummer H3 Steering Rack Reinforcement Kit? Outfitter Designs does not have any in stock!
Old Feb 2, 2024 | 11:16 AM
teahead's Avatar
Old Feb 2, 2024 | 12:04 PM
Happy Hummer's Avatar
Wow!
$211.12 yikes jmho.
I've yet [thankfully] needed this type of item.
Old Feb 2, 2024 | 01:03 PM
Tony-Nav's Avatar
@teahead Last sentence.
Old Feb 2, 2024 | 01:19 PM
Personally, I would wait and go with Outfitter Design, but both/either will work.
Old Feb 2, 2024 | 01:47 PM
Tony-Nav's Avatar
Thanks @Doc Olds . I did reach out to them. I will wait to see what the time frame on restock looks like. I don’t want to cause anymore damage to her driving like this. Note* the steering wheel play isn’t bad but it is noticeable enough to cause alarm on slippery and snow roadways. Whichever happens, I will inspect the wheel bearings also just for S&G’s.
Old Feb 2, 2024 | 04:49 PM
teahead's Avatar
If your issue is play in the steering wheel, it's most likely NOT your rack.
I would go ahead and order these (actually, I did for the play I have in my wheel):
Amazon Amazon
and the lower shaft (3.5/3.7):
Amazon Amazon
5.3:
https://www.gmpartsgiant.com/parts/g...)&location=pd:,
Old Feb 2, 2024 | 05:06 PM
teahead's Avatar
I think the only difference between the 3.5/3.7 and the 5.3 is the 5.3 has the heat shield.
Old Feb 2, 2024 | 05:52 PM
Tony-Nav's Avatar
Thanks @teahead
Old Feb 2, 2024 | 06:48 PM
While under, inspect the> STEERING SHAFTS! & check tire tread depth:
