Master Window Control Button Lights
Old Mar 11, 2022 | 10:15 AM
ik5mdf's Avatar
Originally Posted by wfturner
Here is where I bought the bulbs used in the window switches.
yes, they are easily replaced. Pry up the switch housing, carefully !!!!
Then unscrew the base of the switch module and you will see the bulb bases.
Unscrew old ones and replace and reassemble
These bulbs come with the twist in base and the bulb condom for the correct color.
Buy more, because others will burn out over time.
http://www.ebay.com/itm/Hummer-H3-20...130cf1&vxp=mtr
Here is a better price and just reuse the blue condom from the old bulb
http://www.ebay.com/itm/251327067799...%3AMEBIDX%3AIT
HI!
I found the link you indicated is not working anymore... may you have another solution? need to buy bulbs for windows paddle doors control... THANKS! )))
Old Mar 11, 2022 | 11:40 AM
Originally Posted by ik5mdf
HI!
That is because this is a FOUR YEAR OLD Thread which you should AVOID digging up!! READ: Old Threads/'Necro-Bumping'
You are on the internet........... GOOGLE it. READ Old Threads, do NOT resurrect them.
Hellokitty
Mar 31, 2022 02:19 PM
Hawaz123
Sep 18, 2018 08:56 AM
sgilbride
Feb 17, 2015 04:11 PM
Bosshoss502
May 27, 2011 11:14 AM
machines
Mar 9, 2008 11:05 PM
