Master Window Control Button Lights
Old Dec 2, 2014 | 12:58 AM
Mr_Fulano's Avatar
Default Master Window Control Button Lights
Hi, I'm having a minor problem with my 2006 H3 driver-side electric master window controller. - The small light slots on the buttons for the two front windows do not light up. The rear ones do, but the small slits on the two front buttons do not emit light.
I looked the part up on the Internet and I don't see any bulbs. It looks like a sealed unit. Are there small bulbs within the part? Can they be replaced? Is this something that is fixable, or would I need a new master window controller to fix this problem?
I wouldn't want to change out the entire part just for the small lights, but I would like to fix it if this is possible.
Thank you for your advice,
Fulano
Old Dec 2, 2014 | 07:40 AM
ODIMUS's Avatar
do a search within the forum...there is ton of great info in here...follow the link and towards the last few pages it talks about lights someone used for their door/window switches...
https://www.hummerforums.com/forum/h...removal-16478/
Old Dec 2, 2014 | 06:51 PM
Mr_Fulano's Avatar
Thanks Odimus. Will do.
This is a great forum People really do help other here - unlike other forums I've seen, this one is really cool.
Thanks,
Fulano
Old Dec 3, 2014 | 06:18 AM
ODIMUS's Avatar
Thanks,
Fulano
I've saved some money by reading the forums here...
Old Dec 3, 2014 | 06:44 PM
wfturner's Avatar
Fulano
Here is where I bought the bulbs used in the window switches.
yes, they are easily replaced. Pry up the switch housing, carefully !!!!
Then unscrew the base of the switch module and you will see the bulb bases.
Unscrew old ones and replace and reassemble
These bulbs come with the twist in base and the bulb condom for the correct color.
Buy more, because others will burn out over time.
http://www.ebay.com/itm/Hummer-H3-20...130cf1&vxp=mtr
Here is a better price and just reuse the blue condom from the old bulb
http://www.ebay.com/itm/251327067799...%3AMEBIDX%3AIT
Old Jan 2, 2015 | 12:50 AM
ACannell's Avatar
I LOVE this forum! I assume the switches were sealed until I read this thread. AWESOME!
Old Feb 25, 2015 | 12:37 AM
AR15wheeler's Avatar
Has anyone had the experience of ALL the lights on the drivers door instrument panel not working? All the switches function fine. None of the lights work. Can't be a coincidence that they all went out rite? Is there a wire I should be looking for delivering power to them?
Old Feb 25, 2015 | 02:22 PM
woodwardsh3's Avatar
Mine were all burned out 07 / H3 And replaced all with the ebay bulbs. I removed the blue rubbers on the bulb so they would be brighter they now glow orange and are brighter now.
Old Sep 20, 2018 | 07:47 PM
Ricardo Andres Chaparro's Avatar
I have same problem any solution?
Old Sep 21, 2018 | 11:28 AM
wfturner's Avatar
Doc, won't like me responding to this four year old post, but . . .
Here are the bulbs you need to fix the burned out ones in the light switches.
https://www.ebay.com/itm/Hummer-H3-2...d=271657929969
The entire switch assembly can be pried out carefully from the door panel, then unplug the connector and remove the switch assembly
The bulbs are accessible from the back side of the switch and these new ones come with their own base and just unscrew old bulbs half a turn.
These new bulbs will be hard to find after a while, get them while you can
