Lowering h3
Old Apr 3, 2016 | 08:13 PM
Abarth 1's Avatar
Default Lowering h3
Hi new here just need some info on how to lower my h3 and what parts to use thanks . Any info would help
Old Apr 3, 2016 | 09:17 PM
scoreh3's Avatar
WHY ?
Ok if you really want a lowered off-road truck , you can crank the t-bars the other way and lower the front end . Then for the rear you can use spacer blocks between the leaf springs and axle .
Old Apr 4, 2016 | 09:09 AM
650Hawk's Avatar
Sacrilige!!!
Old Apr 4, 2016 | 10:17 AM
choochmalooch's Avatar
Talking
Like making a silk purse out of a pig's ear.....
Old Apr 4, 2016 | 02:14 PM
lockup7's Avatar
e bay sells a block kit that consists of a 2 inch block, 4 u bolts and a lowered shock mount spring plate, I didn't like the rake in my h3 and had no reason to use it to tow stuff so I purchased it . don't know how far your looking to lower your hummer but I like the way mine sits now. It don't look like a jacked up "HOTROD" anymore.
Old Apr 4, 2016 | 02:18 PM
lockup7's Avatar
ebay item number : 141924044290 just type in the item number in the search box
Old Apr 5, 2016 | 09:42 AM
650Hawk's Avatar
You got that backwards!
Not sure what towing has to do with lowering (or not) the rear end of an H3, but to each his own I guess.
Wow, $170 to lower a 4wd vehicle? I must admit though, even though I would never do it myself, your H3 does look nice lowered (in your profile "garage").
Old Apr 5, 2016 | 10:02 AM
lockup7's Avatar
The back of trucks are a few inches higher because when you load weight on the back , towing a boat, trailer, camper etc. Will bring the rear down. Without the "rake" the back will sag causing the front end to lift thus loss of steering . basic suspension geometry.
Old Apr 5, 2016 | 11:42 AM
Actually, the rake is for aerodynamics per the HUMMER H3 launch book by Larry Edsall.
It gained 0.5 mpg for the highway EPA ratings.
Old Apr 5, 2016 | 12:16 PM
650Hawk's Avatar
You are suggesting that a stock truck will only handle correctly when it is fully loaded, or at least perfectly level. That is not the case. Any vehicle's steering geometry is designed for a reasonable variation of ride height/angle. If that was not true, then your "lowered" rear end has already changed the steering geometry from stock and given you a loss of steering, since it is no longer the "stock" rake, right? And many of us have lifted the front end a couple of inches by tightening up the torsions, which has done the same thing as far as the steering/suspension geometry is concerned as your lowered rear end did (with the exception of a slightly steeper A-arm angle). There is no noticeable effect on steering/handling.
Adding a trailer? Unless your tongue weight is significant, the rear end should not drop much with a trailer, certainly not enough to affect steering and handling. And any trailer with a tongue weight heavy enough to affect it that much should only be towed using a weight-distributing hitch, which nullifies the entire argument.
