Low temp code .. operating temp?
Old Jan 13, 2018 | 10:12 AM
JerseyCoast's Avatar
Default Low temp code .. operating temp?
Sorry for extra topic, but it's not exactly same as cutting fender post I made.
I'm changing the thermostat because I thought it was stuck open. I never get above that 1/4 way line on gauge last 2 months. Plugged in reader, I get a temp of about 170 deg max when running.
When I pulled thermostat, it was closed, so there goes that theory. ( Seems it was working properly)
My question is.... Will a bad temp sensor throw the code? I am reading about operating temp of 200-210? The check engine light has been on entire time with the temp code, a reset just comes back again. Is 170 ish correct? Or should it be higher? If so.... Any ideas? While I'm working on getting new stat back in, figured I would ask. Thinking sensor is next, to get proper reading on gauge?
Thx guys
Old Jan 13, 2018 | 10:35 AM
stuck open or opening at a lower temp causing low temp reading. stay focused on replacement of the thermostat and recheck. GL
Old Jan 13, 2018 | 12:11 PM
BruceS's Avatar
Agree. Stat likely opening to soon or sticking open.
I replied to other post as well. When I ran 180 stat and temps hovered at zero here engine temp would be as low as 160 and no codes or drivability issues. Just less mpg because engine would throw more fuel trying to run warmer. Think about my other reply. Many folks have done the mod and never run warm in crazy hot days.
Old Jan 13, 2018 | 12:13 PM
BruceS's Avatar
Also wanted to mention the gauges are no where reliable. If you are getting 170 on scan tool sending unit is working.
Old Jan 13, 2018 | 01:13 PM
happythree's Avatar
max i see is just over 200 on hot day at idle.
they use a 195 to keep temp up for best performance
Old Jan 13, 2018 | 02:20 PM
Most damage to the engine and components occur at low operating temperature. Optimal operating temperature is between 195-220degrees.
Old Jan 13, 2018 | 06:23 PM
Thank you guys. After a long battle, got it replaced and it was opening at a lower temp it seems. Be stat has the gauge back to normal now.
What a bad spot to put it. Lol.
Thx again, in just a short 15 minute ride, at higher temp, she feels better already. I'm happy this one is over.
Old Jan 13, 2018 | 06:48 PM
Nice work, the only thing to do now is clean the carbon buildup.
Old Oct 4, 2019 | 03:20 AM
wpage's Avatar
Question Where?
Jersey Coast Would you recomend the shop that replaced your thermostat. What was approximate cost?
Thanks!
Old Oct 5, 2019 | 04:47 PM
Thanks!
I actually did it myself. PITA but not impossible. Tight squeeze, need to remove tire. I use Dennis' Service Center in Brick, NJ for the H3 when I cant do it myself. They are very familiar with them.
