Leaking sunroof and potential problems
Old Mar 3, 2020 | 02:34 PM
LatvjuAvs's Avatar
Default Leaking sunroof and potential problems
Leaking sunroof not only will kill BCM, but also will rust out floor.
While crawling under the car I spotted cracks in the body where front passenger feet should be.
I poked it with hand and it broke loose
ignore liquid, it is to stop rust for a moment.
Removing carpet damage was not immediately visible:
Taking off this heat/whatever isolation was pain in the ***(probably there is easy way to do it).
A nice hole, straight to the exhaust pipe to warm feet:
Possibly biggest factor was the heat insulator that trapped moisture in there and it could not evaporate + heat and micro cracks in pain = rust heaven.
Leaky sunroof tube signs:
Next: grind/cut and wield it back together, paint, smear something like fluid film on it and put heat shield back again.
Without heat shielding that place gets hot.
I wonder if I can wrap heat shield(cloth) directly around exhaust.
Old Mar 3, 2020 | 03:58 PM
hummer_on_fumes's Avatar
On the plus side during a road trip you could take a leak out of that hole
GrampaEJ
Aug 12, 2024 09:25 AM
oceanbrave
Jun 10, 2019 03:41 AM
Taneo22
Oct 4, 2018 03:02 PM
johnnyreno
Dec 31, 2014 12:39 PM
eleewhm
21
Nov 4, 2013 09:55 AM
