Key Fob
Old Jul 9, 2021 | 09:03 AM
  #51
An H3 can only read 4 sensors and it does NOT recognize position...... end of story. So the only TPMS that need to be programmed are the 4 on the ground.
Example: if you program sensor 1, 2, 3, 4 and then 5, #1 gets bumped out of the monitoring loop. Assume 1-4 are the tires on the ground. #5 is not sending a signal since it (spare) is not rotating. = TPMS warning light.
Old Jul 9, 2021 | 09:48 AM
  #52
Col Sanders's Avatar
Doc Olds, The 4 in tires were programed when installed. One of the new one's was bad. So the tire dealer put in a new one and gave me a spare. The spare was programed and never installed in a tire., Just put in in console. So I have 4 on the ground, nothing in the spare tire. The odd one in console. Just to keep from getting lost. I did remove it from console and left in house when I had key fob installed. And still have the light on. And that's why I give up.
Old Jul 9, 2021 | 02:36 PM
  #53
Replace those crappy azzed tpms sensors!
Old Jul 10, 2021 | 11:33 AM
  #54
What brand do I need ? That's going to turn off my light?
Old Jul 10, 2021 | 03:13 PM
  #55
You NEED 315Mhz TPMS SENSOR for CHEVY COLORADO GMC CANYON HUMMER H3 H3T OEM Spec
Old Jul 10, 2021 | 03:32 PM
  #56
Originally Posted by 650Hawk
The sensors only transmit when they are moving/rotating. Sitting in your console, they will do nothing.
Sensors transmit when the VEHICLE is moving, doesn't matter where they are!
TPMS PIPE BOMB:
Old Jul 10, 2021 | 06:56 PM
  #57
Thanks for the link to sensors. So I have 5 crappy sensors. 4 in the tires. 1 in console. However, I keep hearing I have a computer problem. I'm going to order the TPMS sensors. Taken a break on this for a little while. Polished H3 today. It really is a nice vehicle...
Old Jul 10, 2021 | 07:24 PM
  #58
Many go quick to the module. 99% of the time it's not the module.
Old Jul 11, 2021 | 07:40 AM
  #59
If it's not the ECM then what ? I do not have the expertise or the equipment to look at it. So the light stays on. It will take about $100.00 plus the TPMS price to get the new ones installed. Like I said before, Dealer wants $300.00 to start. Not going there ever. What to do?
Old Jul 11, 2021 | 09:02 AM
  #60
I would go back to the shop you had install the sensors and tell them to replace the sensors or demand a refund. In the meantime scan and post the codes.
