K&N Performance (633065) Vs GM Performance air intake
Old Aug 19, 2008 | 12:06 AM
Mikeoj338's Avatar
Default K&N Performance (633065) Vs GM Performance air intake
I am looking at buy a performance air intake for my 3.7L h3, i am currently flopping between the two intakes....any comments or input would be excellent thanks
Old Aug 19, 2008 | 08:19 AM
DsH308's Avatar
Default RE: K&N Performance (633065) Vs GM Performance air intake
Not sure whatGM adds but with the K&N intake system it willbump 7.19hp @ 4.3k.
Old Aug 19, 2008 | 09:28 AM
7.19 HP with the hood open? Weak. I like K&N filters, but for an off road truck, an open filter intake design is not the best choice IMO.
GM gets youa plastichromed pipe and a shiny aluminum box lid, and does NOTHING with the pie hole restriction, and costs ya nearly $400.00.
GM does not even have an 08 model yet? [&o]
There is a third alternative.
Crud....I forgot my manners. Welcome to the forums!!!!
Old Aug 19, 2008 | 10:39 AM
Gunner_45's Avatar
I can't speak to the efficacy of other intakes, but I am quite pleased with my AirDoc intake.
Several things set it apart from the rest in my opinion:
It's fit and finish are great. (The construction is actually a bit overkill, but so is a HUMMER)
It addresses the restrictive fenderwell/snorkel issue by increasing the size of the air inlet.
It also allows you to retain your stock breather box. (very important if you wheel your rig at all)
......and finally, you choose the filter that is right for you.
At $149.00........It aint a bad bang for the buck. ( http://airdocintakes.com/product%20one.htm )
I'm using it in conjunction with a PCMsforless tune and the two work great in tandem.
Just my two cents......Let us know what you decide on.
Old Aug 19, 2008 | 10:43 AM
Gunner_45's Avatar
Oh yeah....Here's a link to an oldthread on the forum that might be of interest to you as well.
https://www.hummerforums.com/m_14358..._1/key_/tm.htm
H2Miami
Feb 8, 2015 10:11 AM
phatcatcatena
Mar 27, 2010 09:54 AM
provenceman
Feb 9, 2009 10:51 AM
BMJM100
Jan 10, 2009 02:46 PM
mgurgone
Jul 1, 2007 10:18 AM
