Jackscrew
Old Jan 21, 2021 | 07:18 AM
Lou's Avatar
Lou
Default Jackscrew
I have an easy one. I'm replacing the oil pump and the manual has the part about using two screws as Jack screws to separate the front engine cover. I have no idea how that works. I see myself stripping the cover. How do I use the screws to separate the front cover?
Old Jan 21, 2021 | 12:08 PM
Lou's Avatar
Lou
I found the proper spots to locate the screws.
Old Jan 21, 2021 | 03:37 PM
You gonna share that, or leave this thread you started hanging?
Old Jan 21, 2021 | 04:43 PM
Install 2 bolts into any of the threaded holes to act as jack screws and tighten evenly in order to separate the engine front cover from the engine block.
Old Jan 22, 2021 | 12:46 PM
I was trying to get the OP to do that. I recall when you posted a thread asking people to complete there threads with a conclusion so others can fine an answer if they look it up, which is a good idea every time.
Old Jan 22, 2021 | 05:23 PM
Common sense and a working eye leads you to the conclusion.
Booch
Jan 17, 2020 08:38 AM
ozark1
Aug 31, 2011 08:46 AM
davyo
May 20, 2010 03:50 PM
madmike
Mar 2, 2009 09:15 PM
crank
Jul 18, 2007 08:56 PM
