View Poll Results: Hummer H3 side view mirror, hummer H3 tierod end
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Inquiry
Hi guys
I have 2006 hummer h3 I5. It's driver Sideview mirror is broken, does 2008 hummer h3 driver side view mirror will fit in it or not?
Also I have to change tierod too so it is showing 14mm and 16mm threads of inner tierod for 2006 h3. For my car it's is 16mm from outer side of inner tierod. My question is that the inner end of inner tierod is same same thread as ouer end of inner tierod?
thanks
thanks
Any H3 year side mirror fits any/all H3s.
In mid/early 2007 GM made all H3s with 16MM Tie Rods (14MM were failing often). If you are doing new Tie Rods, replace with a full set of 16MM inner and outer.
I used to watch the robots adjust and tighten the tie rod ends, on the first 2 years.
ChiefUSN
Sep 2, 2019 07:42 AM
nelly27281
Mar 9, 2016 06:24 PM
PeterM
Aug 7, 2011 06:55 PM
