Hummer H3 Duramax Conversion
Old Nov 27, 2019 | 11:43 AM
Originally Posted by SgtChris30
F.Y.I you need the 3 inches of body lift to fit the Allison. It’s touching in a few spots with the 3 inch body lift.
so body is down for fitment. There is a few areas I need to heat and beat for room. Down pipe and an area for the Allison top of passenger side inspection/ pto plate. It looks freaking great to me. The hood barely closes. The oil fill is touching. So I did a 3 inch leveling kit on front with 3 inch body on 37 13.50 22 tires and fuel rims.
Yeah I noticed the oil fill. Add to the body lift for proper clearance on the engine and trans?
Old Nov 27, 2019 | 02:43 PM
no I can’t find the exact size bolts I need for the three inch. Just going to heat it and mold it.
Many options there, shorten/weld the tube, remove trim on oil cap, cutout hood under the grill, etc.. I was more concerned with the trans.. brake torque to make sure everything clears, then your good. Nice work.
Old Nov 27, 2019 | 03:26 PM
it's really coming along nicely. definitely worth your efforts. would threaded rod fix the bolt issues using them like studs instead of bolts? I wonder if head bolts or studs would work.
Old Nov 27, 2019 | 04:41 PM
That's only a grade 2.. I prefer grade 8.
Old Dec 2, 2019 | 06:08 PM
There will be plenty of airflow with the body lift, between the bumper and grill, you can fill that area with mesh.
Old Dec 4, 2019 | 04:06 AM
amrg's Avatar
Its interesting that even at 3" body lift the H3 doesnt look out of place!
I have done a 2" to clear 37s with alot some offset but really wanted 3" for piece of mind (suspension wize). Did u mod the steering column because it was short or to clear engine swap components?
Old Dec 6, 2019 | 03:00 PM
amrg's Avatar
Great progress! Truck looks sharp too
Old Dec 6, 2019 | 05:47 PM
Build Video Update. Body Down for Good.
https://youtu.be/oGMXlzKU4G4
Nice vid, although I was expecting more enthusiasm from your voice, instead you sound worn out and tired. Stay strong soldier, you got this. As long as the body is down and secured with proper bolts? Mods are the easy part. Heat shield/wrap on the batteries is also recommended.
Old Dec 6, 2019 | 06:18 PM
SgtChris30's Avatar
Btw, did you see the H2 Dartz Prombron Black Stallion , and only wants $330k for it.
https://www.youtube.com/watch?v=spGG95LJ9h8
Ugly, but I would rather have over the Tesla cyber truck.
Old Dec 6, 2019 | 06:39 PM
"Blackout and unique", just like your build, for a lot less. Calculating your labor and materials,you can still get a huge ROI if you intend to sell?
