Hummer H3 Duramax Conversion
Old Nov 3, 2019 | 08:16 AM
SgtChris30's Avatar
Default Hummer H3 Duramax Conversion
the bully dog h3 Duramax looks sick wyt
Old Nov 3, 2019 | 11:50 AM
wouldn't the H3 Alpha V8 mounts help get you in the ball park. Love what you're doing keep up the good work.
Old Nov 3, 2019 | 05:55 PM
Old Nov 3, 2019 | 08:00 PM
Originally Posted by SgtChris30
Well after the f150 I bought is total junk. Frame is almost gone. I decided to do an h3 Duramax LBZ Conversion. I will post pictures as i go.
This weekend I have been fitting the Duramax block in the H3 frame and fabing motor mounts up to sit as low as possible. and modifying the gas tank
and the fuel lines and filler neck to work with the dmax. Cutting the inner fenders out. Getting a standalone harness to run the drive train. The front axle
is going to be removed and in the future I will go with the dana 60s like the bullydog h3. Its a budget build with left over parts from all the H2 conversions I have done.
"Budget build", without the paint?
Make it look oem under the hood, no bling, and oem secured harnesses, then you will have 1/1.
Old Nov 3, 2019 | 08:07 PM
Alpha X's Avatar
I decided to do an h3 Duramax LBZ Conversion. I will post pictures as i go. This weekend I have been fitting the Duramax block in the H3 frame and fabing motor mounts up to sit as low as possible.
Cool, looking forward to seeing how this goes together.
Old Nov 4, 2019 | 07:24 PM
Yeah no bling. Just oem and custom fabrication.
Nice work, reminds me of the "sleeper" from the old days. Just don't go doing the crazy paint and lift like the bullydog did.
IMO, min lift and blackout would be cool. Humminator3...
Old Nov 11, 2019 | 07:10 PM
A lot of torque, make sure those mounts are secure!
Old Nov 12, 2019 | 06:53 AM
3 Hockey puck body lift... this is going to be good.
Old Nov 17, 2019 | 06:27 PM
Need about $3500 ish more to finish it so $4500 ish total investment.
Wow, that's lower than I expected! $$$$Keep it low and tight, and let the buyer do the lift and learn. lol
Old Nov 17, 2019 | 06:48 PM
Its going to be my daily driver. I’m getting rid of my truck. The lift is so I can easily work on it.
And fit my 37 13.50 r22 tires and rims.
Just stay @ the lowest possible center of gravity.
