Hummer H3 Door Problem??
Old Oct 6, 2017 | 11:17 PM
Amos Hill's Avatar
Question Hummer H3 Door Problem??
When I open the drivers door, to get out from driving, it doesn't register. This allows the radio to continue to play. At night when you open the door, to get into the vehicle, the lights don't come on. What could be the issue? Every other door works fine....any tips??
Old Oct 7, 2017 | 05:17 PM
woodwardsh3's Avatar
Replace the rubber dome light switch in the door jam, very easy and you can buy them on ebay.
Old Oct 4, 2018 | 09:48 AM
LilMama's Avatar
Does this also fix the issue of the radio staying on? Thank you
Old Oct 4, 2018 | 10:56 AM
It does if the reason it is staying on is because the door jam switch is bad (the BCM cannot tell that the door has been opened to command radio off).
However, if your interior lights come on/go off when the door is opened/closed, then that is likely not it because the BCM is receiving the door signal to command lights on/off.
Temporarily swap a switch from another door and see what that does to test it.
Old Oct 4, 2018 | 01:06 PM
LilMama's Avatar
My lights do not work so I'm thinking it's the door switch. Thank you
Old Sep 12, 2021 | 02:15 PM
mikesbaron's Avatar
I found two switches on my vehicle that were completely toast, no plunger and major corrosion on the plugins. I'm replacing both of the
Old Sep 13, 2021 | 09:04 AM
Mike, this threads is OLD as dirt, please avoid digging up Old Threads, you are responding to people that are long gone.
dkb123
Jun 21, 2022 12:24 PM
Humvee21
Apr 10, 2015 03:28 PM
kyhummerh2
May 12, 2011 08:11 PM
LastLineOfDefense
Oct 27, 2010 01:24 PM
IYF_H3
Mar 7, 2007 01:35 AM
