Hummer H3 2008
Old Apr 18, 2022 | 12:17 PM
DiaboloAldebaran's Avatar
Default Hummer H3 2008
I have a problem when trying to switch from 4up ( locked ) to 4up Normal
1. Start the engine
2. Go to Neutral
3. Hit the 4up button ( blincks then goes steady )
4. Move shift to D ( drive )
5. Does not do anything only a noise like in the transmission but wont engage
Please advice Tks
Am i doing something wrong ?
Is there another procedure ?
Old Apr 18, 2022 | 12:56 PM
You shifted what to neutral? Why? It is done on the fly at any speed less than 45MPH.
Do you have the Owner's Manual and have you read it? They are all online for free review. If you have not read it, STOP driving and do so.
"Shifting between Four-Wheel High and Four-Wheel-High Lock
With the vehicle traveling less than 45 mph (72 km/h), press and release the Four-Wheel High or Four-Wheel-High Lock button.
The indicator light will flash while shifting. It will remain lit when the shift is complete. It may be necessary to drive backwards while
turning for a distance of 25 feet (7.5 m) to get the lock feature to disengage."
Old Apr 18, 2022 | 01:49 PM
the H2 is the one that needs to be in neutral to shift modes.
Old Apr 18, 2022 | 01:50 PM
With the vehicle traveling less than 45 mph (72 km/h), press and release the Four-Wheel High or Four-Wheel-High Lock button. T
My H3 is on " 4up locked " and im trying to switch to " 4up Normal " but as i understand i have to go to NEUTRAL first so i can switch from one to another, is that correct ?
Old Apr 18, 2022 | 02:52 PM
Did you read what I posted??????? H3 Transfer Cases have a 4Hi, 4Hi Lock, and Low Lock. The arrow pointing up is "High", shifting between Hi and Hi Lock can be done at any speed less than 45MPH. You do NOT have to stop, you do NOT have to put anything in Neutral.
To review.... Switching between 4Hi and 4Hi Lock can be done at any speed less than 45MPH. Neutral nothing, get it. READ the OWNER'S MANUAL, that is why they put one in the friggin glove box.
Maybe we have a language barrier going on, but good luck.
Old Apr 18, 2022 | 02:53 PM
IN (D) DRIVE.
Old Apr 18, 2022 | 03:37 PM
Just did what you told me and did not work
Thanks so much
Old Apr 18, 2022 | 03:53 PM
Switch contacts contaminated clean/replace. What codes do you have?
Old Apr 19, 2022 | 09:26 AM
No codes at all
I hit the switch, it blinks then goes steady but then a noise comes from the transfer case ( very similar noise from a std transmission when you dont press the clutch properly ).
Old Apr 19, 2022 | 10:10 AM
No codes at all
OK. Time to look at the threads here about the failed Transfer Case Plastic Shift Fork. When they wear out you cannot shift to/from lock (seems to me most of the time it is discovered when you cannot get the H3 out of Hi Lock to 4 Hi).
Have you tried driving in reverse turning back and forth and then selecting Hi to see if it can free up and make the change? Maybe you can get it out of lock until you have time/parts to do the metal fork upgrade.
The vids below are god visuals, the guy also points out when you do the job you should get a new fluid pump screen.............. some of his comments about "timing" are irrelevant. There was an excellent step by step replacement on line at another now defunct Hummer Forum that would have been a great resource. Might have to reach out to CB Photo and see if he can recreate it????????? He also talks about 4WD not engaging/disengaging.... incorrect, he meant lock is stuck as H3s are always in 4WD..
http://www.youtube.com/watch?v=jZdGyhkJ-bI
http://www.youtube.com/watch?v=Jyfw8EWIY3I
Abdul Rasheed
Jun 4, 2021 11:59 PM
bzh3
Mar 7, 2019 08:18 AM
man-of-war
Nov 24, 2013 05:34 PM
mrs.tnt2
Mar 10, 2013 05:26 PM
dilo2001gt
Mar 12, 2007 11:43 AM
